3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY DJ Turntable from old Computer Parts
How to make a DJ turntable from old computer parts.
Some time ago I have discovered a piece of software that is using the mouse movement (up-down / left-right) to make scratch-alike effects on a virtual turntable, the way the DJs are doing it in clubs. It is the TerminatorX software, developed by Alexander Koenig (http://terminatorx.org/).
But using the mouse is not even close to a real turntable. So here is a way to make from an old mouse and other parts a more realistic turntable.
I have tried several models made from recycled computer parts, and I will present you all of them here.
Step 1Preliminary information
The first think you should know is that TerminatorX runs on Linux. There is no windows version yet. I have tried it in Ubuntu and worked fine. It is in the repositories, so it is very easy to install.
The software is designed to use the movement of the mouse on the X and Y axes and execute a custom chosen action. Usually I use one ax for scratching and the other one for volume control. Also each of the three buttons has a specific function. Left for grab (and scratch), middle for mute the current virtual turntable and right button for change to next turntable.
The turntable consists of 3 parts:
-a mouse with ball and 3 buttons (NOT an optic one)
-a spinning plate
-a table or support for them
Functioning: The spinning plate rests with one edge on the mouse’s rollers and they will spin together. When you spin the plate the mouse will detect it and will send the information to the software.
Materials that I used: one old (but functioning) mouse with 3 buttons and ball, an old CD-ROM, an old hard drive, an old keyboard, a CD, a floppy disk and a vinyl record. For putting the parts together I used double sided adhesive strips and magnets.
31 comments
Jan 15, 2012. 6:13 AMTheRealDutchOwner says:
"You will need a screwdriver with a six pointed star shape..." It's called a Torx-6 screwdriver.
Jan 29, 2012. 2:33 PMsrwoodruff says:
It's not necessarily a Torx-6. All Torx drivers have 6 points, but the sizes range from T1 to T100. Most hard drives require a driver bit that's somewhere from T6 to T10. Some drives may even have screws with a variety of different head sizes.
Best bet is to buy a cheap set from Harbor Freight tools or Fry's electronics.
Mar 4, 2011. 4:18 AMMystBoy says:
Hey i made the same some time ago!
http://www.youtube.com/watch?v=m7XWJ4kmttI
lg
Feb 6, 2011. 2:04 PMjgfresh says:
Yall need to chk out mine its a different take on this.
Mar 11, 2010. 7:24 PMBrunomaster says:
i don´t understand...what is that, what does it do, do something?
Mar 20, 2010. 7:50 PMchrisyo says:
 linux isnt a gui program there for you need to understand computer programing
Mar 25, 2010. 8:32 PMroland985 says:
No, there is a gui, you are just too stupid to know
Mar 26, 2010. 3:59 AMchrisyo says:
classici linux doesnt have gui
Mar 26, 2010. 4:13 AMroland985 says:
Here is proof:
http://www2.mandriva.com/
http://www.ubuntu.com/
http://pclinuxos.com/
Some don't, but those are FLOPPY based distros
Troll
Mar 26, 2010. 12:17 PMchrisyo says:
did i say all? nope
Mar 28, 2010. 12:19 AMroland985 says:
The Linux kernel is GUI free, but you need to know know how to program to make a Distro, but that is not the debate, you seem to be saying that the mainstream Distro he has here has no GUI
Apr 17, 2010. 11:35 AMjli1 says:
 Linux does not inherently have a GUI. Any GUI for Linux is a separate desktop manager, most of them running off of X (Gnome etc.).
A lot of small or server distros do not have a GUI, as it is not needed or practical.
Nov 18, 2010. 1:14 PMIstarian says:
The point is that most desktop Linux distributions ship by default with a particular window manager and they are often referred to simply as Linux. This behavior means that it is sufficient to say that Linux has a GUI.
If you'd like to nitpick though, I'll point out that Linux is not an OS technically. To be specific most are GNU/Linux where the GNU tools are combined with the Linux kernel to produce an operating system.
Server distros do not have GUIs because they consume system resources that could be used instead for the server's purpose. They is also not used because the sys admin often needs more granular (finer) control over the operations which is harder to accomplish using a GUI (without a terminal window). Because all they wanted with the GUI was the terminal window it is simpler, easier, and more efficient to utilize the terminal without the GUI. This frees up memory space for application use and reduces the network bandwidth needed to access the system (even remote x windowing is resource intensive compared to a shell).
Jul 20, 2010. 4:38 PMtomigm says:
the people want a video!
May 1, 2010. 12:09 PMGeli12 says:
 Good!
Can i play games like beatmania whith this? or anybody has a solution?
Mar 21, 2010. 7:06 PMjli1 says:
 Interesting idea... I'm not entirely sure how practical this is, but still its pretty cool. For an even better version of this you could theoretically make a simple program to output midi cc messages from this to any actually nice DJ software (Traktor etc) to make it slightly more practical.
Apr 4, 2010. 8:27 AMPXYZ says:
 I really like your thinking here... theoretically we could set the turntable up as described above and have the mouse wheel for a crossfader...
You could also set up your keyboard keys for cue control etc.
If you have any links for me to check out surrounding this type of information it would be much appreciated (I am a professional dj and would love to hit up a club with personally made equipment)
Mar 15, 2010. 5:17 PMdeclanthedork says:
I made one, and my friend currently has my Ubuntu computer. So I found a Windows program called SoundCraft. Check it out:
Mar 15, 2010. 5:19 PMdeclanthedork says:
If you fast forward to about 0:30 I turned the volume up
Mar 11, 2010. 3:26 PMKillaDilla says:
Wow. Now the hard part, how do I get linux????
Mar 12, 2010. 9:58 AMheadphonedude says:
http://www.ubuntu.com/getubuntu/download
Mar 4, 2010. 1:04 PMeneergcam says:
This is an awesome idea :) but you should try to make a clean version, and myabe incase it in some kind of container or something. my mom has a bunch of CDs that look like vinyl i wanna try to use with this!
Mar 4, 2010. 10:55 PMalexand3rS says:
Addition: It would be extra sick if you could have the disc turn by itself too...
Mar 4, 2010. 10:43 PMalexand3rS says:
OHMYGOODNESS THANK YOU A BILLION TIMES.
I've been looking for *good* *affordable* DJ equipment for some time, and this whip from old parts is a godsend until I can save up for better gear.
Mar 3, 2010. 6:43 PMcdousley says:
yahhhhhhhhhhhhhhhhhhhh i have like 10 old mice and six computer mice LOL
Mar 3, 2010. 3:56 AMplaymoboy says:
Cool. Heres a tip, if the disc isnt making a good grip on the roller add some hockey grip tape to the side of the disc that touches the roller.
Mar 2, 2010. 1:23 PMubr.bzkr says:
I like the ghetto look of this is cool. I have a bunch of old parts like mice and keyboards and HDD disks which arnt as useful for most projects so now i can put them to good use. good thing i saved them, cause usually i just keep the power supplies, HDDs and cd/dvd burners. I assume it will work on puppy linux?
Mar 2, 2010. 12:18 PMLuminousObject says:
This is awesome! Now, to get a Linux computer...
Mar 1, 2010. 9:36 PMComputothought says:
This is is one I have to try!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
16
Author:iurmarius
