DIY Dark Sensor
Published
Introduction: DIY Dark Sensor
Hello guyz
Here is another instructable of making a cheap dark sensor from scratch!
Its Cheap and works fine.
No requirement of arduino or Ic's.
Step 1: Items Required
So, For making this basic sensor , you will be required some basic items which can be easily purchased from a local electronics shop for some bucks.
Here are the parts which are required :-
1. 1 X BC547 ( Very Common Transistor)
2. 1 X 5mm LED
3. 1 X 220k Ohm Resistor
4. 1 X 330 Ohm Resistor
5. 1 X LDR (Light Dependent Resistor)
6. Soldering Items and a perfboard
7. Couple of wires
Step 2: Circuit Diagram
Just follow the circuit diagram and you will get your Dark Sensor ready at no time!
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    • Oil Contest
      Oil Contest
    8 Comments
    Are the resistors necessary if you are using a low power supply
    Hi, nice project, but I have one question, how can I connect multuple leds on this circut? I want to make a small Christmas-like village with lights in and out of houses (street lights) and I want them all light up when it is dark... Is it possible?
    I want to use 12V power supply. Can I somehow connect all LEDs paralel, and then connect them as one in this circut? And which resistors should I use?
    Thank you
    flip the LED around. if that doesn't work flip the transistor around. the are 4 possible orientations between the two.
    I think there's a problem , it does not work !
    To tell you when it's dark.
    Dang, I was hoping for something entirely different.
