Remove these ads by
Signing UpStep 1Parts
- 3.5" SATA harddrive enclosure
- 2.5" SATA harddrive
NOTE: This will not work with a 3.5" IDE enclosure and a 2.5" IDE drive without a special adapter, they have different connectors.
- LED with resistor to power it from 5 Volts
- 3x4 Matrix keypad
- 470 Ohm resistors (4x)
- PIC 16F628A microcontroller
- 5 or 6 Volt relay, 1 Amp should be enough
- 1N4148 diode (Without this you will fry your USB port)
- BC337 transistor (or similar)
- 2K2 resistor
- Some prototyping board
Tools:
- Hot glue gun
- Soldering iron and solder
- Double sided tape
Just wondering any way to use it in a Full Size Tower?
