DIY Death Star Clock
23,016
305
24
Posted
Introduction: DIY Death Star Clock
ThinkGeek Sci-Fi Contest
Finalist in the
Some backstory:  I recently got a 2.5' millenium falcon gift that I subsequently hung in my office...
Well, I got a small wall decal of the death star to put on my wall, but that was sort of... lacking... in some ways.
I decided, why not make a 3D-ish Death Star myself instead?
While I was thinking about it, I also figured, why not make it somewhat functional if I can?
Materials (all available through Amazon and/or your local hobby/craft store):
Lightning "Factory Second" Prostyle #1 Driver  $6.48 shipped
Clock Movement Quartz Square Straight Black Hand Shaft 3/4" Kit   $12.95
(note:  if I were to do it again, I would suggest going with the 1/4" or 1/2" kit instead of the 3/4")
Sticky Back Foam Sheets-Basic Colors   $9.44 shipped
Black and Grey Spray paint about $4-5?
Optional but recommended:  carbon paper - about $5 as well for 10 sheets
Step 1:
So to start off with, I resized and printed out an internet photo of the death star.
Using the carbon paper, I traced the outlines onto the frisbee.
Step 2:
(side note:  if I were to do this again, I would next use my dremel tool and sand away the "emitter / focusing disc" portion as well as dremel in the curved lines -- on this run I did the sanding after I put the foam blocks on and had a few missteps which you'll see on the close up photos below)
Step 3:
Next, I used that same printout photo and traced the outlines onto a sheet of the adhesive backed white foam sheet.  Using a scalpel / X-acto knife, I then cut out the blocks and stuck them to the frisbee, using the outlines as a guide to where they should go.
Step 4:
then spray painted the whole thing in semi gloss black (but any black will work I think) - paint was still wet in this image.  The textural difference between the foam blocks and the frisbee was quite nice once the paint was on.
Step 5:
I used a strip of 1/4" tape to mask the center groove / canyon area, then lightly misted some gray primer to highlight some of the areas and provide contrast.
Step 6:
I then drilled a small hole for the clock nubbin to stick through and attached the clock arms.
Here it is mounted next to my shop clock for comparison
Step 7:
total cost: about $38-39
and the final result hanging in my office next to the falcon and TIE fighter:
2 People Made This Project!
  • I attempted to make ...-dshorter
    dshorter made it!
  • great instructable. ...-Nox_soma
    Nox_soma made it!
  • Sew Warm Contest 2018
  • Paper Contest 2018
    Paper Contest 2018
  • Epilog Challenge 9
    Epilog Challenge 9
22 Comments
Fantastic idea for my nephew, a fan just like me, or members of my Garrison (Dune Sea Garrison in Phoenix, AZ) for special occasions.
What is this lightning "factory second" prostyle #1 thing? Is this the frisbee?
You should purchase a star wars x-wing and tie fighter mini, they're made of light plastic. You can find them online cheap as chips I bet, just a couple of dollars. Attach them to the ends of the hour and minute hands and they'll slowly zoom around the death star on their trench run.
I love your Death Star clock! Nice work. Great detail! Would love to see a DS II version.
Check out the Death Star I & II clocks I submitted as a LEGO Cuusoo project:
http://lego.cuusoo.com/ideas/view/16974
(It's a sort-of LEGO Kickstarter, where if a project receives 10,000 votes, LEGO will consider it for production as an actual set.)
If you like my project, please vote for it!  Thanks!
Sweet! I never would have guessed that started as a frizbee!
This was a fun and easy gift for my Star Wars brother-in-law. Needless to say he absolutely loved it! Thank you for the idea and tutorial! The only tip I have for everyone is to make the arms of the clock a contrasting sheen or color; the arms i used are hard to read when the pass over the black equator.
