3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY Digital Caliper Micrometer Comparator
Get precise measurements with a cheap desktop scanner.
Using free software, you can measure part sizes with a resolution of less than a mil ( 1/1000 inch or about 25 microns ).
Great for identifying mystery micro-screws, electronics, camera parts, or even measuring plants or insects.
Tips and tricks for mounting parts, scanning, aligning the image, and taking measurements.
I'll give you links to other resources where people are using scanners for measurements and would like to hear from you about any ideas or feedback on how to get better results.
Step 1Free Software for Measurement
You can use nearly any graphics software for taking measurements.
The Notes and Resources step of this instructable gives links to notable image measuring software. Three free choices are IrfanView, The GIMP, and ImageJ. All are easy to use for basic measurements.
For simple measuring of lengths,  I prefer IrfanView graphics software.
Keep in mind that The GIMP is excellent and is my main image editor. It is worth your time to learn it as a free alternative to Photoshop.
ImageJ is a scientific and math miracle. Easy to use, but loaded with incredible features. Thanks to i'bler aman0311 for suggesting this.
IrfanView
IrfanView is Windows-only freeware. It is easy to load and use. It is kept up-to-date by its author Irfan Skiljan.
Be sure to download it from the official site IrfanView or from a trusted site like C|Net or tucows.
It installs quickly and easily. It's very light on resources, and is easy to learn.
14 comments
Oct 9, 2010. 9:32 AMaman0311 says:
flattness is an issue, but can be measured by acquiring an image of a known square object, and then drawing a straight measurement line from one sode of the object to another. Bottom line is this boils down to the quality of the optics used in acquisition. Shooting from farther away past a certain point (usually the lahf-way travel through a typical zoom lens) won't improve things. Basically take any lens assembly, set it at it's half-power point, and back up until you can focus in the midrange of the focusing system. Once there your in the best spot to acquire.
Mar 11, 2010. 9:06 AMrobotmastern says:
 very nice. Ive been needing a caliper. this will work in a pinch but i really need to go to the science and surplus store and get a real one
Mar 8, 2010. 12:38 PMkelseymh says:
What a really fascinating application of image software!  And for people who already own an "all-in-one" printer, much cheaper than buying precision machine tools :-)  Well documented as well.
Mar 9, 2010. 8:41 AMkelseymh says:
I doubt it.  If you're in a heay technical field where metrology is crucial (building silicon-based particle physics detectors, for example), then maybe it's obvious.
If you asked the 20,000+ members of I'bles about it, I'd say there might be a few hundred who knew about the concept, and maybe a couple of dozen who could figure out how to make it work.
Your I'ble is a great introduction to a very sophisticated subject.
Mar 9, 2010. 8:36 AMisacco says:
Congratulations for this Instructable! It is useful and well explained.
The idea is simple and smart. It is not a real novelty, but the scanner calibration is a good idea for non flat objects.
I am in the research field and scanning flat objects (examples, leaves or plant roots) for automatic measurement is a usual task. Specialized software are available for this, both licensed and freeware.
A very good free software for complex measurement on digital images is ImageTool
ddsdx.uthscsa.edu/dig/itdesc.html
Bye
Isacco
Mar 8, 2010. 1:00 PMaman0311 says:
You can also use the NIH freeware that runs on Java called ImageJ. We use this frequently in microscopy.
Image J can perform calibrated measurements both hand-drawn as well as morphometric measurements (like mean feret, max/min, area, stuff like that).
Finally the technique you used to calibrate can also be used with any digital camera. Simply take a picture of a known standard, find the pixel calibration, don't move the subject to camera distance and you can smap + measure away. This is best done using an improvised copy stand.
Mar 8, 2010. 1:22 PMLuminousObject says:
That seems to be very useful. And it's FREE! What could be better?
Mar 8, 2010. 3:40 PMNinzerbean says:
I have no need for this but it was a really fascinating 'ible to read, thank you for sharing your knowledge. It's funny but the title is what made me what to know more.
Mar 8, 2010. 2:29 PMTrebawa says:
Idea: if the object is static, scan it a few times and combine them in the GIMP to eliminate the effects of noise and hopefully improve the (effective) resolution.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
33
Author:iectyx3c
