DIY Digital SLR built in-flash diffuser
Step 2Print out template, cut out and tape
I used a CAD software program and made two versions of the template - one is a larger version for more light, I've never tested the smaller version. it just seems more compact.
Just cut out the print out, mount the bottom square part to a card stock/reused plastic with glue and cut out the slits
Cut out the top portion and fold on the lines. Tape the top portion to the bottom portion in the back. Fold on the back and tape the folded part down. This acts as a hinge for the top portion and keeps them together easily. Don't let it get folded or crumpled, this will not let it stand up correctly.
I originally had the idea to use all card stock and cut out a hole in front to glue diffuser material on it. If you do this, you can play with different materials. You can mount gels, different colored office paper, or make slits to act as barn doors for your flash.
It's up to you.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
24
Author:laernmoer
engineer,
