3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY Double Glazing
Step 4Voila! DIY acrylic double glazing
1. peel off the paper and you will have a nice piece of acrylic stuck to your window frame. The air trapped inside will help insulate the room
2. Views through are not affected if you use good quality acrylic
3. If the piece of acrylic is not large enough to cover all of the frame, you will still have some condensation on the exposed bits of aluminium or wood frame.
4. If your magnetic strips have gaps in between them, it will reduce the insulating qualities of this design.
5. close up shows magnetic strips
4 comments
Jul 1, 2010. 8:58 PMwhodatrat says:
I was wondering how thick the air gap is. Does this technique produce any sound attenuation? Thank You Appreciated the instructable.
Jun 11, 2009. 10:56 AMbaustin says:
This is an excellent instructable! So simple yet extremely valuable. Would like to see some prices on the acrylic you used and the magnetic strip. Thanks.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:shanitan
