Step 5Remove Toner
Just remove the Brown tape from the board and got at it with an abrassive pad and the acetone and you should get it off in a minute or two!
Thats one side done, if you want to do the other you'll need to clean the back the same as stage 2, then piercing the graphics with a pin or drill bit, guide it into place using the alignment holes. Iron this side exactly the same as stage 3, don't forget to cover the side thats already been etched in brown tape (as well as the alignment holes) then start stage 4's etching process again.
Once you have removed the tape and toner from the back, you'll be left with a beautiful double sided PCB. It's not quite finished yet though...
Add Comment
