3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY Double Sided PCB/Circuit Board Etching
Step 6Drilling & Tinning
Drilling & Tinning
Nearly There!!!
You'll now need to drill all the holes in the board. I suggest getting a drill press accessory for your dremel to do this, although I'm sure you could do it fine with a steady hand and a bit of patience.
I drilled all the LED/cable holes with a 0.8mm bit and the screw holes with M3 bit. Then using the cutting disk I cut the board to shape and finished the curved bits off with a tubular sanding bit.
Moving onto the last stage we'll need to clean the board ready for tinning (making it look a pretty silver while stopping the copper from oxidizing over time). I use the fine sand paper again and finish off with an abrasive pad & alcohol.
Fill your tray with enough Liquid Tin to cover the board and gently rock it back and forth. You should see the copper start turning silver immediately, but give it a few minutes to finish off before washing the whole thing under the cold tap.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:monstamusic(Monsta Music)
MONSTA is a London based DJ and technology nut. This site covers all aspects of his music life including Mixes, Gigs, Ideas, Projects and other Monstarous activies.
