DIY: Drip Irrigation in the Home Garden With Recycled Material
8,737
23
Posted in HomeGardening
Introduction: DIY: Drip Irrigation in the Home Garden With Recycled Material
We have a home garden full of fruit bearing trees and this is my "Do It Yourself" experience in providing a Drip Irrigation System with recycled material from our bore well.
Step 1: Pump and Water Tank in the Garden
An 1.5 HP Compressor pump is installed in the bore well at our garden. A small 500 litre water tank is being used to store water for irrigation purpose.
Due to some fault in the pumping system, we had to remove about 100 feet of 12.5 mm dia and 25 mm dia flexible pipes from the bore well. When I visited my home during my College holidays, I found the pipes lying in a corner of the garden.  I felt that the 12.5 mm dia pipe with some additional material can be utilized for a small Drip Irrigation System to some of the fruit trees.
Step 2: Additional Materials Procurred
We had to purchase the following items to make the drip irrigation system:
  1. Straight Connectors to join two pieces of pipes
  2. "T" Connectors to make a branching
  3. Taps / Drippers to adjust the flow of water at terminal points
  4. A small packet of M-Seal, a quick sealing, water-proof epoxy compound
  5. A packet of plastic tooth-picks to adjust the water drops from punch holes
Step 3: Tools Used
The tools used are a Hammer, a hack saw blade and a punch from a screw driver set.
Step 4: Reducing the Outlet
The 500 litre capacity water tank had a 25 mm outlet with a ball valve, which required to be reduced to 12.5 mm. Here, we used two small pieces of 20 mm and 16 mm dia pipes to bring down the 25 mm outlet to 12.5 mm. The joints were sealed with quick sealing epoxy compound, which made the joints leak proof.
Step 5: Laying the Pipe Line
From the water tank, we laid the 12.5 mm flexible pipe along the fruit trees. We used the straight jointer to join pieces of pipes and tied the pipe line with trunk of the trees using GI wire. Bricks and stone pieces were placed under the pipe line to prevent it from being burried in the soil.
Step 6: Laying the Pipe Line: "T" Joint
To make a branching, we used the "T" jointer wherever required
Step 7: Checking the Water Pressure
After laying the pipe line, we opened the outlet valve and allowed the water to flow through the pipe line. We also punched small holes using the punch and hammer near the tree trunks where the drip water is required. The water pressure at varrious points were checked and it was very satisfactory.
Step 8: Adjusting the Water Flow
Taps were fixed at terminal points and the flow was adjusted to droplets. The water flow at mid points, where we punched holes. were adjusted to droplets by inserting a tooth-pick in the punch holes. The tooth-picks would also help us to clear blocking of the punch holes by dirt or dust particles flowing with water.
This was my small experiment in drip water irrigation with recycled flexible pipes from the bore well. Any advice for improvement is highly appreciated
    • Spotless Contest
      Spotless Contest
    • Trash to Treasure
      Trash to Treasure
    • Space Challenge
      Space Challenge
    2 Comments
    Looks like it works great! Thanks so much for sharing how you did all this. :D
