3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY Easy Comfort Crochet Hooks
This is a really easy way to make your regular aluminum or plastic crochet hooks into comfort grip hooks by using pencil grips. You can find them in many large chain stores like Walmart, Target, dollar stores, office supply stores, etc. This is a great idea for someone who has sensitive hands (arthritis, carpal tunnel, etc.) as well as for kids.
Step 1Getting the grips to stay on
Wrap your hook handle with masking tape up to the thumb rest (the flat oval in the middle). Depending on the size of the hook you may need to wrap it only a few times or lots of times. I had to wrap my F and G hooks with a lot of tape to get them to the correct thickness in order to keep the comfort grips from sliding off while in use.
12 comments
May 24, 2012. 4:21 AMFunkyBugs says:
I love this idea! Thanks for the tip - I get terrible wrist pain and have to wear a brace to crochet over long periods. Hopefully this will work better :)
Dec 5, 2011. 4:10 PMcraftknowitall says:
I used duct tape, or sugru on all my hooks, and I am one happy camper. Thank you for the idea!
Sep 3, 2009. 3:40 AMMella2013 says:
Oh my gawd you are so smart! Thank you for this idea, I saw an ergonomic hook at the store that was $16 dollars!
Oct 7, 2010. 3:52 AMYoshiB says:
what is an ergonomic hook?
please reply soon
Dec 5, 2011. 4:09 PMcraftknowitall says:
An ergomonic hook, is a hook with a handle that is designed to put less stress on your hand while you hold it.
May 14, 2011. 5:55 AMcairparavel says:
So clever! And it makes it so colorful! I love it!
Nov 16, 2010. 7:15 PMtcup says:
They look great. I use old pens, I take apart a thick pen, then jam the hook inside. Not very descriptive, I know, but it works. The older I get the more difficult it is to hold my crochet hooks especially the smaller steel hooks. Inserting the hooks inside a pen makes handling a hook a lot easier for me.
Aug 16, 2010. 1:39 AMDavidRobertson says:
Try using Sugru.
Jul 29, 2010. 4:10 PMalegriagarden says:
Love this idea was crocheting last night and the tip of my pointer finger was going kinda numb ish cause it was firmly pressed against the metal tunisan hook I think this may solve the problem. A big Thank you!
Nov 20, 2009. 2:26 PMthequiltedgypsy says:
this is a SUPER idea... just too bad i am stumbling across it NOW!!
LOVE IT! i just made a note to get some of these this weekend! :o)
Nov 8, 2009. 9:24 AMGeowyn says:
I make these too! They are wonderful as my hand doesn't get cramped so easily. The only difference is I use plastic tubing instead of masking tape. That way I can easily slide the comfort grip on and off the crochet hook so I can see what size the hook is. You can cut the plastic tubing lengthwise or leave whole depending on the size of the crochet hook. These are so much cheaper than the ergonomic hooks. I love the bright colors of the comfort grips. They are on all my pens and pencils.
Aug 6, 2009. 3:34 AMporcupinemamma says:
very clever. Love that you saw another application for the pencil grip
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:redpaperumbrella
