The bikes were older daily rides that needed work and new paint, so this was a chance to fix them up and install the kits all at once.
Before you get started with a conversion, decide what you want to use as a donor bike, what kind of riding you want to do, the kit you want, and finally the cost. You may be tempted to just get the cheapest kit out there, which might work, but it is best to try and figure out what you want the final conversion to do.
If you need help in deciding the size of motor and battery pack to use, cruise on over to: http://www.evsroll.com/Electric_Motor_for_Bike.html for details on how much power you need. It is interesting if nothing else.
Remove these ads by
Signing UpStep 1: The E Bike Kit
The motor in this kit is a 500 watt continuous, 1200 watt peak power geared motor especially suited for hills. This motor requires a 22 Amp continuous controller.
The brake levers had kill switches on them. Since the throttle is thumb operated, the kill switches and extra wires did not seem necessary. This proved true later on. If you need to stop, you just let go of the thumb throttle, and the motor stops. It is intuitive.
The kits also came with nylon battery bags. These bags are well made, but the battery instructions warn against using these bags! Go figure.
Cost of Kit: $350
Controller: $ 50 extra
Total cost for the conversion including the kit, battery, and parts was about $950
Visit Our Store »
Go Pro Today »
I also saw an article about using the same ( or similar) brushles motors and a lion batterpack do do the same thing for about a $100 bucks, with out board.
I am wondering about using the same components on a bmx bike. Does anybody know if this would work. Could I wire a potentiometer directly between the batter and motor, instead of a motor controller?
You can't beat a ebike most of the time at least...eBikes Rock!
Anyone have advice on what type of battery would be best for me to use?
My bike will have an unusual usage pattern because I spend a lot of time out of the country. It would be used regularly for some of the time and then left unused for two or three months at a time when I am working abroad.
The best type of battery is up to your motor choosing and your bike. Usually, people like to use rear rack lithium battery if you use 48v hub motor. And there is new bottle lithium battery to choose if you like to use 36v hub motor. The rear rack battery can be installed with all bikes. And the botte battery is good fo 26" and 28" male bike. So if you can give me one photo of your bike, that will be a better and exact advice.
Any questions, you can come to cnebikes.
Jason
It seemed to work quite well.
http://www.sheldonbrown.com/frame-spacing.html
Thanks for the article. I'm a bicycle mechanic and realize it's time for an e-bike in my commuter bike stable.
All in all, cool build!
EVsRock!
The complete bike costs around $900-$1,000. This may but seem expensive until you consider that this (and the wife's too) ebike takes me all over the place. It can replace a car for many in town errands. I love the ebike and recommend one to everyone.
Yes, you can pedal in fact much of the time. I have written some pages on the subject since finishing the bike. I explain the pedal assist bike in some detail.
If you are really interested, check here: http://www.evsroll.com/Electric_Assisted_Bicycle.html
EVsRock!
Wheel Size: Other Motor: Brushless Certification: CE
Frame Material: Aluminum Alloy Foldable: Yes Max Speed: 30-50km/h
Range per Power: > 60 km
Packaging & Delivery
Packaging Detail: CTNS
Delivery Detail ONE WEEK
Specifications
electric bicycle conversion kit
12-28''wheel
350-1000w
CCC, CE, ROHS, ISO9001, EN15194
Let's make things better!
FOR EURPEAN MARKET
BATTERY MOTOR WHEEL WEIGHT
24v-10AH LIMN FRONT gear motor 100MM 150w-250w 12"-28"700C 13KG
24v-10AH LIMN FRONT gear motor (100MMwith DISK BREAK ADAPTER) 150w-250w 12"-28"700C 13KG
24v-10AH LIMN REAR gear motor 135mm+6 CLUSER 150w-250w 12"-28"700C 13KG
24v-10AH LIMN REAR gear motor (135mm+6 CLUSER with DISK BREAK ADAPTER) 150w-250w 12"-28"700C 13KG
36v-10AH LIMN FRONT gear motor 100MM 150w-350w 12"-28"700C 16KG
36v-10AH LIMN FRONT gear motor (100MMwith DISK BREAK ADAPTER) 150w-350w 12"-28"700C 16KG
36v-10AH LIMN REAR gear motor 135mm+6 CLUSER 150w-350w 12"-28"700C 16KG
36v-10AH LIMN REAR gear motor (135mm+6 CLUSER with DISK BREAK ADAPTER) 150w-350w 12"-28"700C 16KG
FOR USA MARKET
BATTERY MOTOR WHEEL
24v-10AH LIMN FRONT direct motor 100MM 200-350w 12"-28"700C 15KG
24v-10AH LIMN FRONT direct motor (100MMwith DISK BREAK ADAPTER) 200-350w 12"-28"700C 15KG
24v-10AH LIMN REAR direct motor 135mm+6 CLUSER 200-350w 12"-28"700C 15KG
24v-10AH LIMN REAR direct motor (135mm+6 CLUSER with DISK BREAK ADAPTER) 200-350w 12"-28"700C 15KG
36v-10AH LIMN FRONT direct motor 100MM 250w-500w 12"-28"700C 18KG
36v-10AH LIMN FRONT direct motor (100MMwith DISK BREAK ADAPTER) 250w-500w 12"-28"700C 18KG
36v-10AH LIMN REAR direct motor 135mm+6 CLUSER 250w-500w 12"-28"700C 18KG
36v-10AH LIMN REAR direct motor (135mm+6 CLUSER with DISK BREAK ADAPTER) 250w-500w 12"-28"700C 18KG
LEAD ACID SYSTEM
24v-10AH system OTHER PARTS SAME CHOICE AI LI SYSTEM
Http://www.electricbicycle-conversionkit.com
