DIY Electric Bike Conversion
 by EVsRoll
Featured
Step 5: Install Battery Box
The next thing to do is to decide what kind of battery box you want, measure your battery and controller, select the box, drill some holes, cut a wire opening, and install the box.
 1. Decide on a box. This kit is powered by a 36V 15AH LiFePo4 battery. Instructions with the battery say do not drop, dent, or otherwise injure the battery...in other words, protect it. I decided on a hard plastic box, but later switched to metal. The instructions further recommend padding the batteries in foam.
 2. Measure carefully how much room you need. The box used here is made by Buddy, 12-3/4" x 8-3/8" x 6-1/2". Two of them delivered from Amazon cost about $41. They have locking tops which is good for some security at least. The down side is extra weight of the metal.
3. Ours were mounted on rear bike racks. I took the racks off of the bikes, turned them upside down, marked the holes and drilled right through the rack(s) as needed. Then bolts were just inserted. One thing to do here is put some glue (I use Goop) on the threads since your bolts WILL otherwise work loose under vibration.
 4. Cut a slot for the wires. Remember the wires you carefully dressed to the back? Cut a slot about 1 inch deep and 1/2 inch wide for the wires. I cut this slot at the top of the box using an angle grinder and moto-tool. The lid can still close over the wires, and they can run across the top of the battery to the controller.
 5. Drill the controller holes. Measure and cut 2 holes for your controller just like you did for mounting on the rack. Be careful not to drill the controller!
jimenezlee says: Jul 13, 2010. 8:09 AM
these wires should be protected against cutting on the metal box. Electricians do this at a wire installation to the junction box. So a round hole to fit a plastic plug used in home junction box installations, sold at any hardware store may be better than this slot to protect the cable's insulation against cuts from rubbing the metal, specially because of all the vibration.
EVsRoll (author) in reply to jimenezleeJul 13, 2010. 9:37 AM
Hi: Good point. I neglected to show how I protected the wires. First I insulated the slots with Epoxy coating. Then I just took a piece of tubing, slit it , stuffed the 3 wires in, wrapped a bit of electrical tape around it, and fit it into the box. This works great to seal, protect, and is easy to remove in case of a flat when you need to remove the wires! The photo shows the wires in the tubing.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
