DIY Electronic Dice
Published
Introduction: DIY Electronic Dice
About: Electronic store www.circuits4you.com Design Ideas blog.circuits4you.com Industry www.maventech.in Software fun www.360motions.com
Visit Steps2Make.com
We are living in a digital world, So why not to make a digital electronic dice for game. Here We are presenting a compact Electronic Dice with PCB design. You can break the PCB in two if you want to reduce the Dice size.
Dice have 1 to 6 count. So we are using 7 LEDs that displays the patterns same as Dice. It consists of 7490 Counter IC and CD4093 NAND gate IC. Binary counter is configered to count a 3-bit value such that it can diplay Dice numbers in proper way. This counter is resets when it gets 7 count that will not be displayed. To reset the counter IC2A and IC2B two NAND gates are used in such a way that it makes AND gate and another reset comes from QA. When QA, QB, QC all three bits become High Counter gets reseted. To drive 4 LEDs we have used BC548 transistor.
We need the pulses that are generated at very high frequecy. When Switch S1 is pressed these puses are fed to counter, we can not predict how many pulses fed to counter so we can't predict the what nuber is going to displayed on the dice. Clock pulses are generated using NAND gate oscillator is formed using R9 and C1. For more details on how to make oscillator using NOT gate ? Click Here
Step 1: Components Required
1. CD4093
2. LEDs
3. IC 7490
4. Tecktile Switch
5. 1KOhm, 10KOhm Resistors
6. BC548
7. 100pf Capacitor
Step 2: PCB Designing and Assemble
Download Required Files From Here
1. PCB Layout (1:1 size non mirrored)
You can break the PCB in half to reduce the size
Circuit Uses all digital ICs so no need to program anything just assemble and test it
Have a fun....
    • Make it Move Contest
    • Oil Contest
      Oil Contest
    • Woodworking Contest
      Woodworking Contest
    This looks very cool but a bit beyond me yet. Well done and a Great ible, thanks John :)
