loading
loading
Picture of DIY Electronic Drums (Drum Module Req'd)
So last year I needed to keep things quiet for my housemates, and as a drummer that took a bit of restraint. I surfed around on the internet and found some great web sites after reading about a DIY drum set on Hack-a-day, and what do you know, a month later, I had a full electronic set!
This is kind of a general overview, the basic concepts are fairly simple. I looked at a lot of info out there before building my own, and I just kind of planned it as I built, it just takes a little creativity. Sorry to not include any links, just google it, I couldn't find the specific pages I used, but there is a community of people out there who do this stuff.
So an electronic drum set can run you back $600-3000+, sometimes without a module, my main reason for doing this was to save money bigtime. For comparison the cost for me was around $150-200 for all parts, then the module, so a total of at most $370, which as you drummers know is even cheaper than entry level acoustic sets! The most expensive item was the electric drum module or heart of it all which I will get to later. Heres a quick summary of my bill of major materials and costs:
-Drum pads -> 2 used toms 10" and 12" about 20$ each
-Cymbals -> plastic practice cymbals, $30 for a set
-Bass pedal/stands/mounting hardware -> came from existing acoustic set FREE
(note: I had these laying around, I would suggest being a bit creative about your solution if you dont own a drum set. I had first planned on using pvc or steel pipe, it would be much cheaper as a drum stand can run up to about 100$ for a simple studry one, Perl,Tama etc. The bass pedal might be the only thing you need to purchase, check for used hardware etc, or again, this is Instructables, your crafty people :-P).
-1/4" mono Wires (one per pad) & Electronic parts, $30-40
-Wood -> FREE (scavenged)
-Drum Module, $170 (ebay, "Alesis D4")
Basically I'm trying to convey how little money you would actually have to spend to have a working set minus the drum module. This set, after tuning the sensitivity of the pads (function of the drum module), gets about 4-5 levels of "volume" depending on the power of the hit. It's a great set for practice, and I wouldn't hesitate to play it live if I got the cash for a nice amp together...
1-40 of 93Next »
EddysV1 month ago
can the peizo and foam go on an adjustable internal muffler? at the side of the head
oksmoke212 months ago
Guys, please help me out on this one
I have everything prepared and ready, all the drums are now attached to piezos and piezos to amp wires/connectors. I am getting heavily confused as to how to connect it to a sound module(which i haven't bought yet) and assign sounds to each piezo. If you guys could tell me in detail how to do it, I'll have my set ready at last!
Also, if you could find a way to do that without a sound module ( like getting amp to 3.5 mm jacks and connecting them to the PC, and then assigning sounds using some software), that would be great!
coolkid1094 years ago
So how do I go about making the hi hat so that I can play it open or closed, I'm not concerned about anything in between for right now
you know what "might" work is if you had a foot trigger by your "high hat" trigger and you tapped it when you want a open high hat sound, sur3e it means you have to give up a whole trigger for an open sound reducing the size of your kit, but , just an idea.
ManicDrummer9 months ago
For the lazy you can use DrumsAnywhere. You can convert any surface (a table) into an electronic drum kit with only one piezo.
See http://www.drumsanywhere.com/
TreDiggy2 years ago
Great job man, that's what I'm about to do. I found an old analog Simmons module at the swap meet. I was thinking of you using rock band drum heads but I can't get it apart to see if it has piezos or something else that gives the same effect, has anyone read up on this yet?
doggyd69b2 years ago
I tried a couple of years ago a mesh drumset, it worked great but the door screen mesh just wasn't durable enough, then I discovered the pet proof mesh such as Pet-D-Fence,
and just one layer of that mesh will do the job nicely. Better than the Roland or other name brand mesh and a lot cheaper, $ 20 will buy enough mesh for about 3 five piece drumsets (including the bass drum) for an easy method on how to do mesh heads using that type of mesh check out the tuff mesh website . (http://tuffmeshmaterial.weebly.com/how-to-install-tuff-mesh.html)
siddiq43213 years ago
this siddiq , India,
i have a very cheaper and working method :
1)use the software flexi music orchestra - a very user friendly software to play wav. files etc. on the keyboard
2)download yamaha / ronald / alesis drum samples over the net or from torrents ...they are very quality one and ull have no complaint
3)load all these sample to the key u want for EACH drum/cymbal ...which is pretty lengthy and save it ..
4)then comes the hardware ...use and old PC keyboard -ic ...or if u get confused with the ic pins j...just keep it attached to the plastic sheets which are below the keys ...and the pass out a pin ter . rhe conductor holes ..which is again a time taking job ..but cheap and working
5)now on other ends of the wire ..anttach a piezo...which is the cheapest drum trigger ..of if u r keyboard does not get enouhgh gain on tapping ...the attach 2 /3 in series and keep one above another ,,....and place it beneath the mouse pad (to experiment ) ..the strike u r mouse pad to play ....
was it helpfull ?????/////////////////////////
don't forget to tell me how was it .....
Replyflag[delete]
wont work. piezos generate electricity which is measured to determine velocity. keyboard buttons are simple switches that close a circuit when you push them. you'll more likely fry your keyboard then make a working drum set with that method
View my instructable.......
http://www.instructables.com/id/WORLDS-CHEAPEST-VIRTUAL-DRUM-at-10-Rs500-us/
Check it out.....
Actually i did that circuit accedintely after numorous experiment with that ic.......it works fine with my parameters and ic type in my country....:-)
It sounds a pretty good idea!!
Where is the instrutubles of it??? lol
I want to see what IC PINS you are talking about!
Best regards,
Pedro
did u see those pins ?
plz plz mail or chat me at :- siddiq4321@gmail.com
dont know how much times i have to tell u ...and u reply after 1 month ...LOL
any way let me make the instructable my self and let u know how cool it is .....
hey palmeida ( i dont know what u keep such names )
why dont u come on gmail and chat with me at: siddiq4321@gmail.com
this is the keyboard ic i am taking :
http://www.google.co.in/imgres?q=keyboard+ic&hl=en&gbv=2&tbm=isch&tbnid=ai8z7kheSUpZ1M:&imgrefurl=http://www.okokchina.com/p/Software-/PS2-Keyboard-Controller-IC-424899.html&docid=p6K3PsZurkJ5sM&w=378&h=262&ei=OaR5Tr_MBu_SiAL19tG5Dw&zoom=1&iact=hc&vpx=172&vpy=152&dur=342&hovh=187&hovw=270&tx=165&ty=75&page=1&tbnh=109&tbnw=157&start=0&ndsp=21&ved=1t:429,r:0,s:0&biw=1326&bih=578
u can use to wires and older to any combination of right-lift chips and short them to see the key on wordpad ..then attach a .wav file to it ...short the wires again to play sampple .......attach the piezo and strum it to play .....application : put the piezo beneath the drum pad ....
soon to put its instructable ...
my email : siddiq4321@gmail.com
Thanks Siddi!
That will be my next project.
HAve goods construtions,
Brainsold
what do u mean by brainsold ?
jkaradzic3 years ago
Or you can use a kick PEDAL trigger, like here: http://triggera.com/krigg/
tiengiay3 years ago
So how do I go about making the hi hat so that I can play it open or closed, I'm not concerned about anything in between for right now y8 y8 games
robsedleski4 years ago
I bought a Roland TD-6 that came with a whole bunch of auxiliary electronic percussion equipment included:
-Alesis D4 module / brain
-11 cymbal boom arms w clamps, foams, and washers
-10 home made drum pads (metal plates w foam and rubber covering; piezoelectric sensors with RCA outputs
I just use the TD-6 on its own, so I'm thinking that these items might be of interest to those in this forum. I live in Vancouver, BC, and my email is rob.sedleski@gmail.com.
If you know of anyone that might be interested, please pass this along.
Thanks!
kmoulton4 years ago
know what i am doing fo rthe next few weeks lol... my only question is.. does your piezo actually touch the mesh or is it just slightly below it?
found cheap 1/4" plugs:
http://www.amazon.com/Rean-NYS230-Stereo-Jack-Non-Switched/dp/B0008IV5EO
you can even get away with these if you just want to use your own cymbals with these attached, you could put the piezo between the mute and the cymbal or on top:
http://www.guitarcenter.com/Zildjian-Cymbal-Mutes-Drum-Set-Pack-444388-i1138005.gc
also found some great practice cymbals:
http://drums-percussion.musiciansfriend.com/product/Pintech-5Piece-Practice-Cymbal-Set?sku=444926
some more things i found:
i was thinking about triggers and think i want to use the radioshack piezo's for the cymbals, however, i might want to mess around with either the ddrum triggers or the pintech triggers for the drums. they would fit real nice on the rims and can be placed right under the mesh with some foam in between them and the mesh head (or you can place them on the outside and have them right on top of the head). they already come with quarter inch plugs and would require no extra work. for the price of 20-30 each it's not a bad deal for someone looking to invest a little more into having a complete wired trigger set.
here are some links:
http://www.guitarcenter.com/ddrum-Red-Shot-5-Piece-Drum-Trigger-Pack-101595478-i1136342.gc
http://www.guitarcenter.com/ddrum-Trigger-Kit-105632657-i1135223.gc
http://www.guitarcenter.com/Pintech-Acoustic-Drum-Trigger-with-Trigger-Trap-101188985-i1138288.gc
if anyone has experience with these triggers and has some advice that would be great! thanks again
awesome tutorial! thanks so much for taking the time to put it together so well!
i am starting to put together all of the supplies i need and came across this, thought it could be of use to anyone trying to make one of these:
http://www.musiciansfriend.com/navigation?q=mesh+drum+head
lots of great options in all price ranges for just drum heads all the way to complete sets of snare and toms with mesh heads and mounts.
thanks again!
rbneville5 years ago
I had an idea being as cheap as i am. The software I use lets you use a keyboard to control my vst instruments. I was wondering instead of using a drum module why not take apart a cheap usb keyboard and wire the piezos to the correct keys. Would that work??
pieso transducers cannot act as switches by themselves. you would need to use some sort of switching circuit with the pieso for your keyboard idea; i don't think that it would have a very good response rate for fast drumming, and it would not be velocity sensitive either. you could definitely use a computer keyboard based pad for some effects, though.
crocboy5 years ago
I have the same bass drum pedal, although I recently upgraded to the DW 7000.
MilotisX5 years ago
I just bought an Alesis D4 and i love it! great tut btw but does anyone here no if its supposed to have a backlight?? Mine is very dark, and it doesnt seem right thanks in advance!
 Yes it should have green "backlight" easy to see in the dark
You can also find them in CD-R containers 2 questions 1)I was wondering how the drum sounds without the midi / wav? 2) Would like to know how the signal would hold up if i don't mount anything underneath drum, and just glue or tape the Piezo on the Skin/RemO thing?
geekboxjockey (author)  howangcturtle6 years ago
The peizo will work better on a rigid surface, I haven't experimented too much with placement though. I guess in your case for question 2 I would make sure it is well secured, most drum "add-ons" always find a way to loosen over time :P
hey what is that triangle shaped thing on top of the piezo??
gnargnar7 years ago
i built one of these awhile ago and it triggers the kick when i hit, and when i bring the pedal off. does that make sense? hit=trigger remove=second annoying trigger
is your piezo in the middle of those 4 layers? like 2 under 2 on top?
i was wondering that too but i think it is the way you say because he said sandwiched
kck172885 years ago
I don't completely understand how the hi-hat pedal is working? could you elaborate on it?
cool drum kit
buy a drum module..men you break my heart.... :-P
I've got a Roland electronic set and was looking for a new cymbal. I came very close to paying €300 until I saw this! Could you maybe go into more detail on cymbal construction?
tailortrik6 years ago
find another howto guide on my site! www.homemade-electronic-drums.tk/
1-40 of 93Next »
