3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY Electronic Drums (Drum Module Req'd)
Step 2Bass Pedal/Hi-hat Trigger
These two items were fairly simple and straightforward:
For the pedal, I built a wooden frame that accepted a normal bass pedal, basically an L shape, with reinforcement. The piezo on this was sandwiched between some layers of mousepad and the assembly was placed at the right hieght to be struck by the beater when the pedal was pressed. You cant see in the picture, but the pedal clamps to the rounded bar on a simple door hinge that is in closed position and screwed onto the board on the underside.
The hi-hat trigger was a simple on off sustain footswitch for a keyboard I used to own. Anything that makes/breaks a connection can be used for my set as the module I have only supports an open or close hat, fancier modules can use a potentionmeter I believe for the open-ness of the hat.
5 comments
Apr 9, 2012. 2:01 PMjkaradzic says:
Or you can use a kick PEDAL trigger, like here: http://triggera.com/krigg/
Sep 2, 2010. 7:20 PMcoolkid109 says:
So how do I go about making the hi hat so that I can play it open or closed, I'm not concerned about anything in between for right now
Mar 29, 2010. 5:31 PMcrocboy says:
I have the same bass drum pedal, although I recently upgraded to the DW 7000.
Jul 8, 2007. 3:43 AMgnargnar says:
i built one of these awhile ago and it triggers the kick when i hit, and when i bring the pedal off. does that make sense? hit=trigger remove=second annoying trigger
is your piezo in the middle of those 4 layers? like 2 under 2 on top?
Jan 9, 2010. 1:10 AMWarlock_12 says:
i was wondering that too but i think it is the way you say because he said sandwiched
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:geekboxjockey
