3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY Electronic Drums
Converted my Roland TD3 KW Electronic Drum Kit. Upgraded it to a TD6 module with meshhead drums.
Step 1Cut tom drum in half with jigsaw
I found this tom on eBay for $30.00. The price included shipping. This tom was cut in half with a jigsaw to create two 10" toms. I used tape around the cut line to prevent splintering.
48 comments
1-40 of 48next »
Jul 6, 2011. 3:04 AMsiddiq4321 says:
this siddiq , India,
i have a very cheaper and working method :
1)use the software flexi music orchestra - a very user friendly software to play wav. files etc. on the keyboard
2)download yamaha / ronald / alesis drum samples over the net or from torrents ...they are very quality one and ull have no complaint
3)load all these sample to the key u want for EACH drum/cymbal ...which is pretty lengthy and save it ..
4)then comes the hardware ...use and old PC keyboard -ic ...or if u get confused with the ic pins j...just keep it attached to the plastic sheets which are below the keys ...and the pass out a pin ter . rhe conductor holes ..which is again a time taking job ..but cheap and working
5)now on other ends of the wire ..anttach a piezo...which is the cheapest drum trigger ..of if u r keyboard does not get enouhgh gain on tapping ...the attach 2 /3 in series and keep one above another ,,....and place it beneath the mouse pad (to experiment ) ..the strike u r mouse pad to play ....
was it helpfull ?????/////////////////////////
don't forget to tell me how was it .....
Replyflag[delete]
May 11, 2012. 1:09 PMmattcc says:
The only problem is you can play 2 keys at the same time :/
cant*
Mar 31, 2012. 11:50 PMthealeks says:
piezos wouldn't work with a pc keyboard, they generate electricity, whereas the keyboard buttons are simple switches, temporarely connecting the circuit
Apr 1, 2012. 12:07 AMsiddiq4321 says:
U need to see my instruc.
http://www.instructables.com/id/WORLDS-CHEAPEST-VIRTUAL-DRUM-at-10-Rs500-us/
Cheers...:-)
Feb 21, 2011. 3:25 PMrobsedleski says:
I bought a Roland TD-6 that came with a whole bunch of auxiliary electronic percussion equipment included:
-Alesis D4 module / brain
-11 cymbal boom arms w clamps, foams, and washers
-10 home made drum pads (metal plates w foam and rubber covering; piezoelectric sensors with RCA outputs
I just use the TD-6 on its own, so I'm thinking that these items might be of interest to those in this forum. I live in Vancouver, BC, and my email is rob.sedleski@gmail.com.
If you know of anyone that might be interested, please pass this along.
Thanks!
Sep 23, 2010. 9:14 AMdhane says:
hi.. can you help me to make a circuit? i have a boom sound and i wanted that every time i hit the pad the sound it produce is the boom sound which is mp3 format that i have..
Aug 22, 2010. 3:26 PMpady_j says:
im in the process of converting my acoustic kit into a mesh head, triggered Alesis DM-Pro metal blasting machine but i made a test drum like yours and i ran into a problem. i made a drum pretty much identical to your design. my problem with it is instead of my drum being too sensitive (which seems to be everyone problem on the internet who is trying this), is it's not sensitive enough in the fact that i have to hit it way too hard to get sound out of it. i tried putting less foam on it, my settings on my Roland SPD-S are too the max sensitivity and lowest threshhold, im wondering if maybe its my peizo i bought. its from a peizo buzzer i got from The Source (radio shack in canada). my materials besides the peizo are all identical. i was wondering if you or anyone ran into this problem or could help me figure this out. thanks.
Jun 17, 2010. 8:10 PMbigredlevy says:
I simplified the design a bit by removing the adjustment mechanism. it's a bit harder to set up initially, but i guess equally less work in construction.
Perhaps as a result of the design changes, i got a LOT of crosstalk and double triggering. i moved the piezo to the top of the foam block, but this has resulted in a few sensitivity issues.
I'm running the piezos through an arduino serial converter -> virtual midi port -> ableton. response isn't great, but that's due to lack of processing power.
everything i used is here (i didn't actually buy it, just gleaned the site for info)
thanks for the instructable. LEVY
Aug 6, 2009. 7:15 AMtommah04 says:
when I made a few and hooked them up I was getting ALOT of crosstalk, any tips (besides messing with the module) I could do to help this?
Dec 12, 2007. 3:11 PMkruser495 says:
nice, glad to see that there are other drummers than me on this site.
Jul 26, 2009. 12:29 PMwiebevandomburg.hotmail.com says:
me too!!
Jan 22, 2008. 12:09 PMdrummonkey92 says:
my sentiments exactly can we get a petition goin sayin more drum based instructables n less k'nex? lol
Jul 26, 2009. 8:43 AMavwos says:
4th signature
Jun 17, 2009. 4:26 PMUberNoober says:
I would SO sign that one! :D
Apr 1, 2009. 9:26 PMDarkFireSquirrel says:
Haha so true...
Mar 10, 2009. 8:50 PMgnargnar says:
agreed!
Apr 15, 2009. 4:49 PMsmallman98 says:
i agree
Mar 10, 2009. 8:54 PMgnargnar says:
i'm picking up two toms and a floor tom for thirty bucks tomorrow hopefully, so we'll see if this instructable makes as much sense when i'm actually destroying perfectly good drums eh? you wouldn't happen to live in southern california would you? you need to make one for cymbals now. the new "surge" cymbals that alesis has look pretty sweet and do-able. maybe even some sort of appliable surface on the bottom so you don't have to ruin cymbals...? i'll work on it
Feb 16, 2009. 10:48 PMMilotisX says:
The Glossy blue finish didn't completely crack and get destroyed when you started to cut?
Feb 8, 2009. 12:59 PMo48Mike says:
WOW! I came here looking for something to turn gum rubber pads into mesh pads and I found this! I'd really like to do this sometime if I could convince my dad to do it with me since he's the handy man of the house. Just need a couple cheap drum shells since I'd likely make a bass drum too. But I do have a question. How would you do a double trigger drum with only one plug? My drum module only supports a single plug in but it has two triggers one for the head and one for the rim. Would I need peizo in there and just have it wired to the same port? Thx man I really hope I get to do the full kit conversion because I'm hatin' the electronic kit my parent's got me for x-mas I have cymbals and drums breaking left and right on me.
Feb 7, 2008. 6:30 AMQuestionConvenience says:
Great instructable. Good pics, concise instructions, good idea, and nice execution. Do you get paid for this?!
Oct 29, 2008. 10:16 AMdg33 says:
Can you get paid to do instructables???
Sep 20, 2008. 9:15 AMrabid_chickin says:
Could you post a video? Ive always been skeptic of the quality of standalone triggers and i wanted to see if it could pick up ghost notes. I was also wondering if anyone knew how to get rimshots to work in a kit? Does it take another trigger entirely?
Aug 14, 2008. 12:29 PMtailortrik says:
find another howto guide on my site! www.homemade-electronic-drums.tk/
Jul 3, 2008. 7:16 PMgradof6b says:
I have a question about your buket drum kit. Wouldn't it have been easir to just use the sensors in the yamaha drum kit and basically just rearrange them?
May 27, 2008. 7:24 AMRockmanAU says:
Thanks for the replies Mike.
May 26, 2008. 2:43 AMRockmanAU says:
Hi, You said, "I used tape around the cut line to prevent splintering." Q: What sort of tape did you use for that? Thx in advance, Rock
May 26, 2008. 2:51 AMRockmanAU says:
Hi, You said, "These jacks where not long enough to go through the drum shell. With the right size drill bit I was able to screw the jack into the shell. It was a nice tight fit." I don't follow you here, I understand that the Jack plug may not fully seat if the female socket doesn't protrude enough but please explain how you overcame this & made it fit. You lost me there. Thx in advance.
May 26, 2008. 2:56 AMRockmanAU says:
Hi There, Is the sensor support a static device or does it have some suspension. I am guessing it's static and the suspension comes from the foam in the sanding blocks only. Please clarify for me man. Thank You, Rock
May 26, 2008. 2:59 AMRockmanAU says:
Yo, Could you give me an idea of what these sensors cost you, what type/model/specs they are & where you got 'em please? Thank you Mike, Rock
May 26, 2008. 3:03 AMRockmanAU says:
Good Job Mike, Great when it all works fine! Rock
Dec 13, 2007. 8:54 AMdrummer ian says:
nice instructable, what kit does every1 play here?
1-40 of 48next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
12
Author:mikejl47
