3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY Electronic Drums
Step 12Foam sanding block
Foam sanding block
I cut the foam sanding block into 1"x1"x1.5" foam blocks with a miter saw and peeled of the sanding surface.
I tried the foam cones. Had triggering problems like double triggering, miss triggering . Made many adjustments to the module with no success in getting it to trigger properly.
The sanding block foam blocks work great. I was able to set the module back to the default settings. No triggering problems at all.
1 comment
May 26, 2008. 3:03 AMRockmanAU says:
Good Job Mike, Great when it all works fine! Rock
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
12
Author:mikejl47
