DIY Entertainment Center
Introduction: DIY Entertainment Center
This is my first instructable, hope to share more.
Wanted to put a flat screen in my office, had three bookcases and thought they would just fit together and make an entertainment center. But - they didn’t! The TV was actually too big to fit between all the pieces with them butted up together. I came up with a way for only $20 bucks to make the TV fit and turn the cases into one Entertainment Center.
Project can also be seen on my website pocketmerlin
Step 1: Planning
In my head these three cheap pieces would just fit together perfectly, as usual my head was off with the measurements. The TV was just a little too big. I didn't want to blow another $100 minimum on an entertainment center so I spaced out the cabinets as they would need to be to make the TV fit.
Step 2: The Build Up.
I increased the surface of the smaller bookcase by 4 inches adding 2x4’s to the sides and then cutting down a plank to make a top for it.
Step 3: Bridging the Gap.
Then from the same plank of wood I cut out 2 more shelves to tie it all together. Stained it all up using a lighter color than the three original bookcases. I wanted to try and make the different colors blend using a cross between the darker sides and lighter middle.
Step 4: Assembly
Used standard wood screws straight through the side cabinets into the shelves to join everything together. Highly recommend a drill with a level in it and pre-drilling your holes before screwing. This will help eliminate the risk of splitting through the shelf or cabinet.
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    • Paper Contest 2018
      Paper Contest 2018
    Clever way around a sticky problem...!
