DIY Fancy Paper Winter Snowflake
Published
Introduction: DIY Fancy Paper Winter Snowflake
About: I ride and compete in Hunt seat Equitation but have done many equestrian sports. I am a artist with a large pallet of interests, from digital, game design, coding, sketching to Chinese brush painting and Tur...
Materials
  1. Paper, preferably thin so it is easier to cut when folded into layers
  2. Scissors, perhaps a large pair and a fine tipped pair
  3. Pencil ( optional )
  4. Snowflake template
Step 1: Step 1:
  1. Start with a piece of square paper
  2. Fold it in half, diagonally
Step 2: Step 2 :
  1. Fold the triangle in half, it should now be four layers thick
  2. Turn the triangle so the base is towards you
  3. Bring on of the corners on the end( not the top corner) towards the center
  4. Overlap the second corner so the edge is lined up with the crease on the already folded edge
Step 3: Step 3 :
  1. The two corners should overlap
  2. Trim the two tails or triangles from the main triangle
Step 4: Step 4:
  1. Use a pencil to draw this pattern shown
TIP: look up cutting patterns on Pinterest or online for snowflakes
Step 5: Step 5:
  1. Cut out the pattern
  2. Pull apart the snowflake
TIP: If you don't cut far enough or right, the snowflake may turn out differently, the shape will not be a circle, it will span from the center. In other words, the design will look like a regular snowflake shape.
    • BBQ Showdown Challenge
    • Stick It! Contest
      Stick It! Contest
    • Backpack Challenge
      Backpack Challenge
    3 Discussions
    AMAZINGG!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
