Introduction: DIY: Felt Rose Ring { Tutorial }
This felt rose ring was a project that I did few years back and was my first time doing a ring using felt. It was originally based on a ring that a friend purchased elsewhere and I thought I could pay for less and make my own. So I experimented it myself at home. I am happy the way it turned out, quite versatile as I can make it as a brooch, earrings or a headpiece.
Have fun!
Also check me out or follow me at { every little thing }
Step 1: You Will Need:
Felt or other fabric (I chose indigo blue)
Scissors
Ring band
Needle
Matching colour thread
Step 2: Cut Out As Much Petals As You Wish.
I used 11 petals. You can cut more to make your rose to have more volume. My petal size is within 1 inch x 1 inch.
Step 3: Take a Petal and Put a String at the Tip of the Petal (the Side That Is Narrower) As Show in the Picture
Step 4: Pull the String Tight So That You Create a Shape Like This. Tie a Knot to Keep the Shape. Repeat These Steps for the Rest of the Petals
Pull the string tight so that you create a shape like this. Tie a knot to keep the shape. Repeat these steps for the rest of the pedals
Step 5: You Should Have Something Like This
Step 6: Take Four of Them and Sew Them Together.
Tips: One petal should overlap the other (like a fan)
Step 7: You Should Have Something Like This After Sewing the 4.
Step 8: Repeat Another Set of 4 and a Set of 2. Keeping One Petal Remaining.
Step 9: Now, Stack the 3 Sets Together and Sew.
You should have 2 sets of four's and 1 set of two's. Make sure the set of two's is at the top. Tips: Distribute the petals evenly
Step 10: Now Mold the Two Petals in the Center and Squeeze a Bit Inwards and Secure With Thread.
Step 11: Use the Remaining Pedal and Roll the Tip to Something Like This and Secure With Thread.
This will be used as the center pedal.
Step 12: Fit the Petal Into the Center and Sew in Place.
Tips: you might need to trim the center petal a bit if it appears to be taller than the rest of the petals.
Step 13: Cut Out the Same Size Circle As the Ring Blank From the Felt.
Step 14: Sew the Circle to the Bottom of the Rose.
Step 15: You Should Have Something Like This. Now Glue the Circle Onto the Ring Band Circle Area.
Step 16: Ta La~ You're Done!
Fashion Contest
Jewelry Contest
