Step 3Creating the "gap" spacer
Get a pliable plastic top from a can of nuts (ideally clear) and trace the circle that's the size of the bottom of the d-pad.
Cut it out and punch a hole in the center that the pivot point on the bottom of the d-pad assembly can fit through.
Put the d-pad assembly back into the controller housing and then put our spacer on top of the assembly.
Put the d-pad membrane on top of the spacer (it'll be snug now).
Put the rest of the buttons and membranes back in and close up shop.
BE CAREFUL when tightening the screws. They strip *very* easily. A good trick for fixing a stripped screw is to put some of your larger sanding shavings into the hole with tweezers and then insert the screw.
comments
Add Comment
Add Comment
