Fixing a Old Broken Computer Cooling Fan With a New DC Motor
2,729
32
15
Posted
Introduction: Fixing a Old Broken Computer Cooling Fan With a New DC Motor
In this project i will show you how to fix a broken computer fan with a new fan.
I found this computer fan in my junk collection, which was not working. I tried to repair the fan with the same motor but no use, the chip which controls the motor was fried so came up with this Idea of using a new motor.
Step 1: Making Video
You can watch the video of fixing the fan or continue reading for the steps involved.
You Can Subscribe To My YouTube Channel Here : https://goo.gl/ctc8l9
Step 2: Things Required
1. Broken Computer Fan (Fan & enclosure separated)
2. Hot Glue Gun
3. DC motor (capable of running between 5 to 12 volt)
4. USB Cable
5. Remote Button (found this in my junk collection)
6. Deo bottle cap
7. Any container cap (diameter 10Cm)
8. soldering rod, soldering wire & soldering paste
9. Stripper
10. Scissor
11. Super Glue
12. Battery & Battery cap with clips
If you interested in making this product you can use my affiliate buying links :
Amazon US:
Computer cooling fan : http://amzn.to/2acNUk6
Hot Glue Gun - http://amzn.to/29Y2BU8
DC Motor : http://amzn.to/29Qg9lO
USB Cable - http://amzn.to/2a3wlCS
Soldering Kit : http://amzn.to/29RyXjJ
Wires - http://amzn.to/29Y1kwt
Battery - http://amzn.to/29Y0Shu
Scissor - http://amzn.to/29Y1K65
Super glue - http://amzn.to/29Wvpi1
Wire Stripper & Cutter - http://amzn.to/29RBsm8
Amazon India :
Computer Cooling Fan - http://amzn.to/2a0r3sq
Hot Glue Gun - http://amzn.to/29HEslT
DC Motor - http://amzn.to/29X8X79
USB Cable - http://amzn.to/2a5dCWj
Soldering Kit - http://amzn.to/29P00wv
Wires - http://amzn.to/29GdPBl
Battery - http://amzn.to/29HEp9E
Scissor - http://amzn.to/29P2ECE
Super glue - http://amzn.to/29HHbvK
Wire Stripper & Cutter - http://amzn.to/2a0wBD8
Step 3: Motor Attachement
1st Image - Make a hole in the center of the container cap so that motor shaft can pass through
2nd image - Glue the motor to the container cap
Step 4: Motor Cap
1st Image - Make a hole in the center of the Deo bottle cap
2nd Image - Insert the USB wire through the hole.
3rd image - Solder the wire to the motor and glue the cap over the motor
4th Image - USB pin configuration
Step 5: Fan Attachement
1st Image - Make a hole in the center of the fan bade
2nd Image - Insert the remote button and glue it
Step 6: Combining the Motor, Fan Blade & the Outer Cover
1st Image - Attach the fan and the motor
2nd Image - Make some holes in the container cap so that air can flow
3rd Image - Mark the outline of the outer cover on the container cap
4th image - after marking cut the excess with a scissor
5th Image - Glue the container cap to the outer cover (be very careful while gluing make sure the blades are not touching the outer cover
Step 7: Finished Images
To the watch the video of the testing please go to the step 1 or CLICK HERE
Testing Begins @ 7:03
Do you want to support my videos?
If Yes, Please browse and buy things from my Amazon Store. This way I get a small commission which will help me produce more videos. Please use the link to visit my store : http://goo.gl/gKjns4
You can also contribute to me on Patreon using the link : https://goo.gl/JHoagv
Amazon US:
Amazon India :
Follow & Subscribe Me On for more Cool Projects :
You Tube : https://goo.gl/ctc8l9
Twitter : https://twitter.com/MakeStuff_MS
Instagram : https://www.instagram.com/makestuff_ms/
Google Plus : https://goo.gl/RpTnwf
Facebook : https://www.facebook.com/makestuffMS
Also please do read or watch my other instructables
THANK YOU FOR READING !!!
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
15 Comments
Try to fix that broken wing (not sure hoe its called) becouse fan will vibrate
That blade is broken into pieces, No idea how to fix it.
You are right about vibration. While testing at low speed(5 volt) it did vibrate but at high speed(12 volt) vibration is negligible.
You can counterweigh it by cutting off parts of the opposite wings. But honestly. I would just salvage another fan since there are so many thrown away.
Counter weighing by cutting off the alternate blades would work.
Thanks for the help.
i won't recommend counter-weighing it, you might end up with nothing,
since many fans (like the one above) have odd numbered
blades set.... lol
So what would you recommend or any suggestion ?
take ThomasK19's advice.... "salvage from another(defective) fan" ;)
I just notice that you could glue counterweights inside the hollow part of the fan. Again, it's probably not worth while the effort.
I'd salvage a working fan from a defective computer ;-)
Otherwise Dremel away pieces from the opposite blades until it does no more shake. Of course that will reduce the fan's efficiency even more.
