DIY Flashing LED
Published
Introduction: DIY Flashing LED
About: This is Electronic Project Forum which aims to help new members to build easy D I Y ( Do It Yourself ) Electronic Projects
Hi to all Today's the instructable is about the FLASHING of an LED which can be
used in so many different application exp decorating , indication etc
This is very simple instructable anybody can do it.
D I Y IN 4 MINUTE COMPLETE VIDEO GUIDE STEP BY STEP
I use a 555 timer ic to generate frequency which can be tuned to
different levels of frequency by using the potentiometer
A buzzer used is optional here
PNP / NPN transistor can be connected at the output if we need to derived a bulk of LED OR Motor etc
Different electrolytic capacitors can be used to set the desired delays at
output i tested different electrolytic Capacitors in the last minutes in my video
PLAY VIDEO
Step 1: Hardware Required
All the hardware details including circuit diagram are given in the video description
Step 2: Working
CHECK OUT THIS AMAZING LED FLASHER IN VIDEO
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    • Clocks Contest
      Clocks Contest
    7 Comments
    hai! can u try do it with piezo? and how did u know what to use to light a bulb (like resistor etc? thanks!
    hi miraheng you can use a piezo
    it will work the same
    for lighting a bulb at the output you need to connect a bulb 6v relay at output but this is good for lower frequency switching
    but for faster switching at output we need to do something else ...like using power transistors etc
    First off, thank you. A well laid out Instructable. But, where is the PNP transistor you mention in the initial description? And I'm not seeing it in the "Hardware Required" list. I'm really new to this and last week ordered all the goodies to put something like this together, so this is timely. I don't see what I think a PNP transistor would look like used anywhere in your circuit, either.
    Thanks for letting me know
    PNP transistor is optional here
    if we need to derived a big load rather than LED .like motors OR many LEDs .
    But for a single led it's optional here .
    I forget to mention in my post
    but don't worry it will be updated soon.
    If you could possibly show both circuits, one with the transistor and one without, I would appreciate that. I'm getting so that I kind of understand the workings of the components, but their practical application is difficult. Thanks, again.
    these are two circuit one with NPN transistor and other without transistor
    you can use any small gain transistors like
    2n3904
    2n2222
    bc547
    these are very common
    if you feel any difficulty please ask
    thanks
