DIY Flex Sensor
Published
Introduction: DIY Flex Sensor
About: Completes Bachelor of engineering (electronics and instrumentation engineering). Worked in Tamil nadu textile processing Ltd erode. Working as service engineer in a reputed company. Intraday trader, DIY ...
A cheap way to flex sensor. It will be very useful for your projects
Step 1: Things Needed :
flexible tube
LED(any colour)
LDR(light dependant resistor)
Step 2: Join It
Fix one of the tube with LDR and another end by LED.
Supply power to LED.
when you bend the tube the resistance changes at LDR with respect to luminance of LED.
Step 3: Interfacing to Arduino
It gives voltage as output thus it is connected to analog pin.
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    • Clocks Contest
      Clocks Contest
    4 Comments
    Awesome idea m8. das a sunlight and other light sources interfere a lot ? and if so have you tried putting it in a black shrink tube or painting it black ?
    yes it does affected by other luminance source which is greater than LEDs luminance and your idea will be helpful for it.
