3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY Flexible Printed Circuits
Step 3Print on Pyralux
Print on Pyralux
Draw up a design in any graphics program, then use the manual feed tray to print it on your Pyralux sheet in black. Cyan, magenta, yellow, green (50/50 cyan+yellow), red (50/50 yellow+magenta) also seem to work, just avoid light shades that are composed of tiny dots on a white background. Printed areas will be protected with wax, and wind up as copper traces on your layout.
Note added 3-7-08: Use "high resolution" or "photo" mode when printing. This printer setting is typically available in the "Print Setup" menu of your graphics program. High-resolution mode prints more slowly and seems to promote better adhesion of wax to copper.
10 mil (250-micron) wide lines and spaces were printed from a Tektronix Phaser 850, which is an older model.
In most Phasers the copper side should face down when it goes in the manual feed and comes out upside down. Give a little push if the manual feed cog has trouble grabbing onto the sheet (more likely with thicker sheets)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
14
Author:ckharnett
