3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY Flicker Lamp or Electric Candle
This is a very easy, cheap project that uses easy-to-find materials. It requires no special skills or tools. Once you have the base completed, you can quickly make customized "shades" for any occasion.
Step 1Gather Your Supplies
For this project you'll need:
1. One extension cord. You need the type that has a flat end with three outlets. There is usually one outlet on one side and two on the other; the bottom two can be covered with an attached safety plug thing. Check out the photo to see what I'm talking about.
2. One glass ashtray. Mine came from Wal-Mart and is made by Anchor Hocking. The extension cord's business end needs to fit inside the ashtray as shown.
3. A plug-in light bulb socket. It's just what it looks like; you plug it into an outlet and screw in a bulb. I can't remember where I got it but it was probably at a hardware store.
4. A flicker bulb. These are in the candelabra bulb section and run about $3 each. They have two flat plates inside them that make an orange, flickery light, and they use 3-7 watts. Do NOT use a regular candelabra bulb. Regular bulbs throw off a lot of heat and could become a fire hazard.
5. Florist's tacky putty. You can get this in the floral section. It comes in rolls and is usually green. Don't try to use Sticky Tack (the stuff you use to stick posters to the wall). It's not strong enough. You could probably use duct tape if you can't find the putty.
6. One sheet of decorative 12 x 12 scrapbook paper. You might want to get an extra sheet, just in case.
7. Clear tape, ruler, and scissors
9 comments
May 11, 2008. 1:00 PMtackam says:
I think it would be pretty to make one out of simple cardstock and instead of gluing/taping it in a circle, punch holes and lace it up, like a corset, with pretty ribbon or cord or whatever. Many possibilities for this lamp, thx for the post. :)
Dec 17, 2007. 8:23 PMczarina28 says:
These are super easy! I made a bunch of em tonite. Great for xmas! Couldnt find the florist tack but a glue gun seems to be holding.
Oct 27, 2007. 1:40 PMJanek says:
nice one.. now they're selling similar ones (candle type) with some kind of sensor that reacts to blowing on it.. so you have a flickering led or bulb in a real candle and you can put it out with just blowing on it.. and you can turn them on the same way.. any ideas what kind of sensor if it is a sensor is used?
Sep 16, 2007. 7:11 AMkricketone says:
cut the bottom out of a pumpkin and cut your face in it looks great
Sep 12, 2007. 2:35 PMTossManual says:
Seems pretty well done - good work. I was hoping you'd have an LED flicker lamp circuit that would be cooler (literally), but yours is way cool. ;)
Sep 12, 2007. 10:03 AMHoyt says:
Practical, simple & totally customizable. Thumbs up!
Sep 12, 2007. 12:42 AMwestfw says:
That's a clever way to make and secure a "lamp socket"...
Sep 11, 2007. 7:21 PMPatrik says:
Hm... now you have me wanting to make a Flickr lamp...
Sep 11, 2007. 2:49 PMPatrick Pending says:
This would make a good lamp for Halloween if you stick on an appropriately spooky silhouette. Cheers, Pat. Pending
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:CraftyTeacher
