3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY Floating Pool Volleyball Net
Step 2Build It: Cutting The Pipes
Using your blueprint, start cutting your PVC pipe to the sizes you need. For my 10' frame, I used the following:
1 60"
2 30"
2 24"
4 12"
8 8"
Once you're done cutting, you'll need to debur the cut ends. You can use sandpaper or a dremel. Wear a mask while while you're doing this as the PVC particles can be hazardous.
Cut the noodles to size. Make them a little longer than the pipe that you plan on putting them on. You can always cut more off later.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:Flea
