Step 3Make your panel
Next it is time to make your... ehrm... (nonprinted) PCB. I use a sloppy piece of wood which is great because it will not give you any electrical shortcut by itself. My wiring is made of non-insulated copperwire which wired around nails of copper. Every wiring around each nail is also soldered.
The basics around this simple circuit for this pedal is read from a site called loopers-delight.com. For your convenience, I qoute them here:
"The circuit for a switch connected to the Footpedal jack is very simple. It is just a resistor and a momentary switch connected in series between the tip and sleeve of the jack. Pressing the switch connects the tip and sleeve together through the resistor. The resistor values determine the function that the Echoplex executes. These switches can be in parallel, although if you press several at once you will get unpredictable results."
Since these values are not exact I just took the closest one from the resistor E-series. Can´t remember if it were E12 or E24 though. The table of the expected values is provided here aswell, so you can go figure it out.
Add Comment
