DIY Four Jaw Lathe Chucks Spindle Headstock Tailstock Homemade Wood Metal Mini Lathe
Published
Introduction: DIY Four Jaw Lathe Chucks Spindle Headstock Tailstock Homemade Wood Metal Mini Lathe
This small welding chuck are made for small-size welding positioner in the processing nice work for wood and very easy for do it in home
Materials:
1 pcs motor 50 Watt take from old hand drills
1 pcs steel 80 mm x 10 mm for chucks
1 pcs aluminium alloy 100 mm x 800 mm x 12 mm for Bed
1 pcs aluminium alloy 100 mm x 80 mm x 40 mm make hole 32 mm
2 pcs 32 mm x 12 mm x 10 mm miniature deep groove ball bearing
1pcs pulley 5 mm x 20 mm and 1 pulley 12 mm x 80 mm
More Step by Step Homemade Mini Lathe DIY Wood Milling CNC Router here:
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    • Oil Contest
      Oil Contest
    You have given me an idea for a chuck on my 1960 vintage wood lathe. It has a smooth 5/8 inch shaft and does not accept the jaw chucks one usually sees.
