Step 3Advanced Flamethrower
1) solvent the 3/4 inch pvc (about 6 inches in length) into the bottom of the tee junction (the bit of the tee which is at a right angle to the other bits.)
2)attach the copper tube to the 1 inch pvc( the one inch pvc should be about 4 inches in length). How you do this is up to you... i used blu tack and some pieces of plastic to wedge it in place then i put pvc solvent into the junction.
3) now you should have a long copper tube connected to a 4inch long 1inchpvc pipe and a 3/4tee connected to a 6inch long 3/4 inch pvc
4) slide the 1" pvc into the mouth of the 1.5l bottle (in the picture I've used a 500ml bottle because i didn't have a spare 1.5l bottle at the time). IMPORTANT: Dont attach it though otherwise you will have no way to put the deo inside the bottle...
5) slide the tee connected to the 3/4inch pvc onto the copper tube until you can hold the bottle in one hand and the 3/4 inch pvc in the other. Wedge it into place again with different combinations of plastic pieces, blutack, and pvc solvent. (IN this case, the 6 inch long 3/4 inch piece is just a handle to hold the flamethrower with so that you don't burn your fingers on the copper pipe when it gets hot...)
6) you're done!
Add Comment
