3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY Free Motion Cycling Rollers
Step 2Split the PVC Pipe
Split the PVC Pipe
First measure the length of your rollers. Then add 24"to that because that gives 12 inches of rolling space on each side, this is how long you will cut your PVC, if it adds to more than 8ft(I don't know of any rollers this long) it is OK, as long as you have at least 8 inches on each side. Make the cut there so you have your length of PVC. Now run this through the table saw long ways so it splits in half, you may have to flip it over and cut twice if your blade is not high enough, I did. Just make sure you don't twist the pipe too much while running through the saw. If you don't have a table saw and only a jig saw, just do your best and tell me how it worked.
1 comment
Mar 1, 2010. 12:20 PMkissiltur says:
I'm thinking that it would be a good idea to temporarily attach the uncut pipe to a length of wood to run along the fence. Two options:
1. hot glue
2. make the pipe longer and used screws in the ends
Apart from the twisting, this would also be safer since there is more for your push stick to shove at.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:pennachi1
