3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY Front Surface Mirror
I see there is a lot of laser enthusiasts on this site (including myself), so
I decided to share some of my experience of making front surface mirror.
Original idea belongs to
I used acrylic mirror for my design.
It's not the best solution but it's very easy and safe to work with and quality of mirror would be acceptable for most laser/optic applications.
So if you are interested, check out my materials:
Here's my another, more advanced, method of making FS mirrors using
Winning Colors Stain Remover.
This safe and reliable method works with any acrylic or glass mirror.
Step 11.
1.
Procedure is simple.
Put on safety glasses and gloves.
Cut piece you need.
28 comments
May 23, 2012. 2:51 PMmcm1303 says:
OK, I understand this thread is four years old now but in case anyone is still listening:
How long do these front surface mirrors last? My understanding is if they are made with Silver Nitrate they will oxidize(?) or darken within a short period of time. Is that the case with acrylic mirror?
Dec 7, 2011. 2:29 PMsgt_rock says:
This product is not winners colors stain remover here in the us either. It is winning colours stain remover and is available at home depot.
Nov 16, 2010. 11:39 PMerniehatt says:
Hi, has anyone in Australia found a suitable product.
Im looking, will post If I find anything. Ernie
Nov 19, 2010. 6:20 PMerniehatt says:
Found Motsenbocker's Lift Off #5 , here in Brisbane
Oct 6, 2010. 2:26 PMbratan says:
I don't know if it's acrylic mirror I use, but even the most delicate painter's tape, will strip away pain and mirror finish when I remove it :( Good news is that you don't have to put it on at all. Instead of file I used dremel with sandpaper and it's very good for rounding square off. It melts plastic off, but leaves edges smooth, and it's really much faster than file :)
Sep 19, 2010. 7:51 AMVickal89 says:
Hello
Can you tell me which product is similar to this "Winner Colors Stain Remover"? I tried paint thinner (ruins my acryl mirror) or kitchen oil/fat cleaner (doensnt work at all), but it all fails.
I want to avoid to run to the homeworker store thousand times always buying the wrong thing. Can you tell me which features this product must have? Unfortunaly I dont live in US so we dont have "Winner Colors". But I am looking for something similar.
Can I use nail enamel remover for this?
Thank you for your tutorial btw. Its great!
Sep 19, 2010. 9:49 AMVickal89 says:
tried this with fingernail paint remover from my sis. It works, but the paint is pretty persistant, so i have to scratch a little bit with my fingernails. The result is not very satisfiying (OK though, pretty scratchy).
Sep 20, 2010. 3:04 AMVickal89 says:
tried it with round glass mirrors today.
Works pretty well with nail paint remover. Have to scratch though, but the mirror surface is more persistant than on glass than on acryl.
Aug 16, 2010. 1:06 PMbratan says:
Hi, I'm trying to understand the purpose of this procedure. What exactly are you removing and why? Wouldn't mirror work as is if you just glue it with non-reflective side to the fan? I'm there's a reason for this, I'm just trying to understand what it is :)
Aug 18, 2010. 7:07 AMbratan says:
Thank you! Now it's perfectly clear! You should add this info the original article :)
Jul 22, 2010. 3:05 AMbabak.ehsani says:
Also I am Sorry i cant become a pro member...and i couldnt see the all step... if anyone can help about this kind of parabolic acrylic mirror ..please help! Email : Babak.Ehsani@Gmail.com
Jul 22, 2010. 3:00 AMbabak.ehsani says:
hi sorry i didnt understand what is this...Is this steel or iron plate or somthing else? i want to make a parabolic acrylic mirror.. can i make it by my self?
Apr 14, 2009. 12:22 PMkatzmatt says:
will this work on a glass mirror?
Apr 14, 2009. 8:34 PMkatzmatt says:
Oh ok and could you reccommeend some other brands or the contence of the super strippa or where you got it and where to get the mirror for cheap because I tried one and it went all the way through sometimes and not far einough other times btw you can find glass cutters at home depot and settle for square or rectangular mirrors
Dec 5, 2008. 11:42 AMlemursquad says:
Oh, and acetone will pull off the mirror surface easily. At least it did for me with the mirrored acrylic from Tap Plastics. However if you use Mötsenböcker’s (which is water based), you won't need the acetone. After you strip, rinse the residue off with water and dry with a clean soft rag. Worked like a charm for me.
Dec 5, 2008. 11:31 AMlemursquad says:
For the record this works awesome:
1. Mirrored Acrylic from Tap PlasticsTap Plastics
2. Mötsenböcker’s Lift off 5Mötsenböcker’s Lift off 5 Latex Based Paint Remover
Mötsenböcker’s doesn't damage the mirror surface or the acrylic at all. You have to let it sit for awhile though, about 5+ minutes. You shouldn't have to "rub" to get the paint off, if you let it sit long enough, the paint will just float off. Using a synthetic paint brush and LIGHTLY brushing the surface helps speed up the process.
Try it on a practice piece first. It worked flawlessly for me.
Jun 21, 2008. 6:06 PMfred_dot_u says:
I was not able to find the specific product noted in this instructable and instead, purchased some "green" citrus smelling stuff. It worked great in removing the paint from the back of the mirror tile I used. The instructions said 30 minutes to ten hours, but the paint was loosened in about ten minutes or less. I then tried to further remove the silver back coating by leaving it on overnight and it only barely started to speckle the silver loose. If you find the "indoor-approved" citrus stuff, it might be a better product, plus it is designed to be washed off with water. The Home Depot has some relatively inexpensive acrylic mirror tiles.
Sep 9, 2008. 3:55 AMwupme says:
You can use that Fingernail Stuff that women use to get the color off. Its the same thing, just a lower concentration. Its a bit more expensive in the end, but hell.. you're not gonna make a couple hundred mirrors, right ? :)
Feb 28, 2008. 7:12 PMporksmash says:
I tried removing the paint from an acrylic mirror with acetone, but it started removing the mirror finish before all the paint was gone as well! Any more detailed tips?
May 17, 2008. 3:04 AM_soapy_ says:
Top tip: clean the backing off first, then cut the mirror to size. The silver layer will protect the acrylic underneath for a short time, only damaging the edges. Then you can cut to size carefully to get a perfect bit of mirror.
Apr 20, 2008. 5:56 AMminorite says:
thank you for posting this.
Mar 27, 2008. 8:43 AMPapagiorgio says:
pardon my ignorance, but is this a one way mirror?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
90
Author:AP Digital light
