3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY Fuel Ionizer for real cheap. Really works.
Step 6Applications and benefits
As it is cliched "in the end" problem solutions always cost the least if paid for adequately at outset of the vital problem's recognition. Being vital, the problems are evolutionary, inexorable, and ultimately unavoidable by humanity. The constantly put-off or under-met costs and society's official bumbling of them clearly prove that man does not know at present what wealth is nor how much of whatever it may be is progressively available to him
-R. Buckminster Fuller . ý
BENEFITS.
• Build E.L.V.I.S. yourself for $3
• Easy to install
• Significantly improves fuel economy
• Greatly improved pickup and power
•Higher combustion BTUs
• More efficient burning of fuel
• Eliminates hard carbon buildup
• Significantly reduces all emissions
• Reduces crankcase emissions
• Helps maintain engine oil integrity
• Less engine maintenance and down time
• Cleans Injectors and maintains fuel system
• Significantly increases tune-up interval.
• Decontaminates fuel
• Extends filter and engine life
• Kills algae in fuel system
• Eliminates need for harmful, costly biocides
• No maintenance required.
• Improved engine reliability
• Helps compliance with emission laws
• Significantly increases engine life
• Easier starts
APPLICATIONS OF E.L.V.I.S.
Any gasoline engine:
Cars, trucks, motorcycles, boats,
chainsaws, weedeaters, leafblowers, lawn
mowers, air compressors, generators
Any diesel engine:
Cars, trucks, buses, tractors, marine engines,
generators, industrial equipment,
oil-fired home heaters.ý
Vegetable Oils.
Lipids do ionize but more research needs to be done in this area.
2 comments
May 16, 2010. 1:00 AMdrasser says:
sorry I meant the pressure would be to high wouldn't it.
May 16, 2010. 12:58 AMdrasser says:
with fuel injection the pressures would be to high for the home made one wouldn't they? I would like to try this on my tundra v8 but don't want it to blow apart on me. Is there a high pressure container that I could use? Or would the one you show be okay for fuel injection?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
11
Author:makenakai
