Step 8Before/After comparisons
1. Straight flash
2. Stofen Omni-Bounce
3. AG Bouncer
3 Simple Ways to
Share What You Make
Other ways to share:
Flash diffusor/bouncer an another way
by
KresimirPregernik
$0 flash diffuser for a DSLR
by
biozz
Easy & Cheap Flash Diffuser
by
amyles
DIY build in flash diffuser
by
bosslytan
Budget flash (strobe) diffuser
by
peterbryenton
diy diffuser for sb400
by
ldpcmember
Diffuser for a pop-up flash
by
eejit
Comments: 90
Rating: 4.78
© 2012 Instructables
All Steps Viewing
1. Make sure you build it so the bumps on the plastic are on the inside, and the smooth surface is on the outside.
2. If your flash has a "wide panel" use it (along with this diffuser).
The first time I built this, I didn't do either of those - and saw mediocre results. But after turning it inside out, and using the wide panel, I see really excellent results.
I don't have a light sphere to compare to, but I have a couple other light modifiers (a Hughes reflector, and a Fong origami), and this is much better than either of those.
Thanks for putting this out there!
Nonetheless, I love this thing. Since the rolls are dirt cheap at Ikea I might mess with a few design changes to see if I can create even softer lighting!
#1...Straight flash...ech! But that was the point, right? :)
#2...IMO, the most natural coloring of the subject of the the three. A fill light below or to the side would have eliminated the shadowing. HOWEVER, if you look at the resulting flash color from this diffuser, it has a green tint on the wall behind. (I work on a color-corrected monitor for work [photography for the web and print catalogs], so it may show up as a different tint on someone else's monitor.)
#3...Virtually no shadow, but the stool is over-lighted.
I agree with others...a human subject would most likely be a better example, as there are varying color tones and textures, rather than a black object.
Some other items to test with is macro photography. Using a diffuser makes a HUGE difference over straight flash!! I've only used my own, using the thin packing material sheets, but the difference is amazing. One of these days, I'll get around to posting an 'ible for a different one that can have different options (unless someone beats me to it).
Here's another thought...you can cut about 3 of these out of the liner material and that leaves a strip about 4.5cm wide...you probably have some extra velcro...use these to make a small diffuser for your pop-up flash!
Great addition, especially if your "large" flash has remote capabilities - or you're off without it!
(I use the Pentax AF-540-FGZ with my Pentax K-10D)
