DIY Glove Controller With E-Textile Sensors
7,146
108
4
Posted in TechnologyWearables
Introduction: DIY Glove Controller With E-Textile Sensors
About: designer, leather ninja, tech explorer, ruiner of manicures
This Instructable is a step by step tutorial on how to make a data glove with eTextile sensors.
The project is a collaboration between Rachel Freire and Artyom Maxim. Rachel is the glove textile and eTextile sensor designer and Arty designs the circuits and software. In this Instructable Arty will be making the glove textile, following Rachel's instructions to test our tutorial.
There is a full list of materials with links in the next step and the .PDF pattern can be downloaded in the third step
The glove was designed with VR in mind, but can be used for any number of applications which sense the movement of the fingers. The range of the sensors is not huge, and because we are using textile sensors, their readings will vary for each glove made.
This is the simplest version of the glove using stretch resistive fabric as the sensors. They are connected using wires and the circuit is on a breadboard.
To see more wok-in-progress images, go to our Flickr album here: https://www.flickr.com/photos/rachelfreirestudio/...
Step 1: Materials and Tools
https://jaycotts.co.uk/products/fray-check#.Wi_lQ0tpHMU
MATERIALS:
1. Fabric
- glove: Two-way stretch fabric such as lycra. I am using Eurojersey Sensitive Touch as it is a super fine micro knit, so very flat and good for layering with bonding materials --> http://www.sensitivefabrics.it
- cuff: 2.5mm neoprene
2. Bonding material
Bemis Sewfree fusing (stretch bonding film) http://www.extremtextil.de/catalog/Sewfree-elasti...
3. Conductive Materials
- Sensors: Eeonyx resistive stretch material: https://www.sparkfun.com/products/14112
- Conductive thread: I am using Elitex, though any good conductive thread will do. There is an amazing list here: http://www.kobakant.at/DIY/?p=379
4. Electronics
-insulated silicone wire (30 gauge): https://www.daburn.com/2615-Ultra-Flexible-Silicone-Rubber-Wire-UL-3132.aspx I use this because it is super flexible, but any wire will work well, such as the ribbon cable in the pictures
-jewellery wire (for sewing loops)
-male pin headers connectors: https://www.sparkfun.com/products/116
-shrinktube
TOOLS:
Sewing:
- sewing machine
- dressmakers scissors
- tiny sharp scissors
- rotary cutter (optional)
- iron
- hand sewing needles
- strong thread
- dressmakers pins
- fabric pen, gel pen or chalk
- fray check https://jaycotts.co.uk/products/fray-check#.Wi_lQ0tpHMU
Connectors:
- soldering iron
- round nose jewellery pliers (or needle nose pliers)
- helping hands
Step 2: Prepare Your Pattern and Materials
Step 3: Cutting Out
Step 4: Making the Sensors
Step 5: Applying the Sensors to the Glove
Step 6: Sewing
Step 7: Strain Relief
Step 8: Finished Textile!
Step 9: Making a Wire Harness
Step 10: Stitching Wires to the Sensors
Step 11: Measuring Sensor Resistance Range
Step 12: Assembling Breadboard Electronics
Step 13: Final Result
Step 14: What's Next?
  • Science of Cooking
    Science of Cooking
  • Pocket-Sized Contest
  • Microcontroller Contest
2 Questions
what about programing
Very good point! The code we used for the initial design unfortunately had to all be re-done at the last minute, and our project time ended. This was a collaboration and we both went back to our respective corners of the globe. When Eeonyx manufactured the stretch resistive fabric it was very different than the samples we had used for development. Our initial project was structured as a step by step tutorial. We would have had to do quite a lot to update it accurately and unfortunately ran out of time. But the physical design still works great and each time you make a textile circuit you always need to recalculate the value of the pull up resistors. It can be hooked up to any microcontroller you are familiar with. So we figured putting up the practical documentation for the textile was still valuable.
First of all awesome project.
Secondly I am developing a glove similar to this one for a teleoperation project with an Arduino mega microprocessor.
I noticed that in step 12 you used a capacitor across the voltage divider could you tell me why you did so and how to determine what capacitor to choose?
it is to smooth the reading from the etextile stretch sensor which is pretty noisy. If you want more details you would need to ask my collaborator Artyom Maxim as he was in charge of the circuit design beyond the textiles and he also wrote the code:
https://www.instructables.com/member/artyommaxim/
I would like to see your glove project too. Will you post it on here? For other cool datagloves, check out KOBAKANTs DIY etextile dataglove overview:
http://www.kobakant.at/DIY/?p=6730
4 Comments
Hello, I placed online orders to get all the materials for this wonderful project.
One thing I do not see on this page or on the flickr album is how to sew the buttons to close the glove... Would you happen to have anything you can share ?
This project was a huge motivation for me to learn how to sew. I'm wondering if you have a good technique for the buttons...
Thank you so much,
Will
Actually, I'm seeing how easy it is on YouTube... All best !
The next tutorial demonstrates how to use this glove to simulate touch-screen on an ordinary monitor, right? I can't wait :)
awesome! i Really like the Design. :)
