DIY Glowing LED Skull LESS THAN $10
256
Posted in TechnologyElectronics
Introduction: DIY Glowing LED Skull LESS THAN $10
This is my under $10 Instructable made in my robotics class which has alternating LED Lights and requires only 2 CR2032 batteries to power.
Parts:
3v Lithium 2032 Coin Batteries 10 for 4.50 (90 for 2)
Breadboard Male to Female Jumper Wires 40 for $4.99 (4 for $.50)
2xCR2032 Coin Button Cell Battery Holder Case on/off Switch Black $4.23 (1 for 1.41)
Velleman MK 102 Flashing LED Kit $2.99 Frys.com
Pumpkin Halloween prop Dollar store
Equipment
Soldering iron
Solder
Soldering tip cleaner
Glasses
Wirecutter
Screwdriver
Step 1: Soldering
DO NOT DO STEPS 5 & 6 Yet Wait Till End Will Use Battery Cell & Jumper Wires
Step 1: Attach 1k resistors (Brown,Black,Red) to R1 & R2 then Solder
Step 2:Attach 10k resistors(Brown,Black,Orange) to R3 R4 then Solder
Step 3: Place Trimmers into Circuit Board (Both are 220k): RV1 & RV2 then Solder
Step 4: Place transistors into :T1 & T2 then Solder (It is fine if it sticks out a bit make sure it is flat though.)
Step 5 Solder jumper wires into circuit board: LD1 & LD2 then Solder
Step 6:Attach LEDs to jumper wires (Make sure negative side of LED is connected to negative side of jumper wire)
Step 7: Solder Battery Holder into circuit board: 9V (Solder into corresponding sides)
Step 8:Place Batteries into Battery holder then turn on
Step 2: End Result
Change jumper wires for fitting length depending on Prop.
Step 3:
    • Spotless Contest
      Spotless Contest
    • Trash to Treasure
      Trash to Treasure
    • Pocket-Sized Contest
    5 Comments
    At the very bottom click next then click on the Movie attachment
    I see! You should upload your video to YouTube so you can embed it. This would make it viewable on the site vs needing to download a video.
