DIY GoPro Hero Hand Clamp Mount
2,492
61
Published
Introduction: DIY GoPro Hero Hand Clamp Mount
Equipment Needed:
Draper 152mm Spring Clamp ( or similar)
1/4" Nut and Bolt (from most hardware shops, harder to find in the UK)
Tripod Adapter Mount Bracket Stand For GoPro
Tools Needed:
Drill
6 or 7mm drill bit
Flat Head Screw driver
Adjustable spanner
Step 1: Drill Hole
Drill a hole at the top of the handle on the Hand Clamp. The drill bit I used was about 6 or 7mm, I'm not sure.
Step 2: Insert the Bolt
Push or screw in the bolt through the hole. The bolt head should fit snug on the inside of the Hand Clamp Handle. Once you've done this just add the nut to the other side and tighten using a spanner and screw driver.
Step 3: Add the GoPro Tripod Mount
Screw on the Go Pro Tripod Mount to the top of the bolt and then attach your Go Pro
    • Oil Contest
      Oil Contest
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    2 Comments
    Love clean and simple ideas like this! Awesome!
    Great idea, and so simple! Thank you.
