D.I.Y Grounding Plate
1,443
7
Posted
Introduction: D.I.Y Grounding Plate
Grounding is practical, useful and sometimes necessary or even life saving. This instructable tells you how to build a grounding plate. Similar to the ones you see at most Firework factories and workshops dealing with micro-components. You usually put it near a door or desk to prevent damage to components or ignition due to ESD (electrostatic discharge)
Step 1: Materials
You will need:
A cardboard box measuring around 20x17 Cm (7.5x6.5) Ins
Aluminium Foil
Wire
Tape ( Electrical or Duct tape works best)
A 100k Ohm Resistor
Blue tack or double sided tape for mounting (optional)
A three pin plug (three blades)
Step 2: Prepare the Box
Open the box and make sure the shape is perfect
Close it and cover the top with foil and tape it on
Step 3: Prepare the Wire
break the wire to make a length about 5 Cm (2 Ins) long
Attach the wire to the foil from inside the box
repeat but attach on the opposite side
Join the two to the main wire and tape it down
Step 4: The Resistor
Make a hole in the base of the box and take the main wire through
After taking it through, tape it to the base and break again
Attach the two ends and to the resistor
Tape this assembly down
Step 5: The Plug
After taping the resistor down, attach the plug to the free end of the wire the wire should go to the Earth/ground pin (the top pin)
Remove the other two blades/pins
Step 6: Testing
You will be able to find many sites online that tell you how to test grounding
Step 7: Operation
Plug the plug in to a wall socket
Put your palm onto the plate
PS. Do not bypass the resistor or leave the two other pins in
They are both safety features
the resistor is to prevent shock in the event of a short circuit, if the wire touches the 2 other pins and they are connected you could die
Also, don't touch anything else when in contact with the plate
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
  • Paper Contest 2018
    Paper Contest 2018
2 Comments
