DIY Guitar Speaker
2,268
50
12
Published
Introduction: DIY Guitar Speaker
I found this cheap old classical guitar sitting in my storage, deformed and unplayable, so I decided to turn it into something more than a decoration.
Step 1: Preparation
Tools I use for this project:
1. Jigsaw. (Cut holes on the guitar)
2. Drills. (Drill holes for the power and 6.4mm jack).
3. Screwdrivers. (Disassemble amplifier).
4. Torx screwdriver (Disassemble amplifier, depends on the model you got).
5. Soldering iron. (Solder speakers & rewire onboard power and audio input).
6. Desoldering pump.
7. Scissors (Cut the wire).
Step 2: Choose Your Speakers
Go search for the right speaker for you on the internet, I'm using a set of 4" Full range 8 Ohm speakers. I found this set best suited for the color and style of the project.
Step 3: Choose Your Amplifier
Again you can search the internet for the amplifier suitable for this project. I choose Lepai LP-A68 amplifier as it resembles the volume control panel on electric guitar. You can find it on Amazon: https://www.amazon.com/s/ref=nb_sb_noss_2?url=sear...
Step 4: Get Other Parts
Step 5: Make a Plan
1. Take your time and plan where to put your speakers, amplifier, phone jack and dc input.
2. Measure and draw the cut lines.
Step 6: Disassemble the Amplifier and Rewire
1. Solder the wires connects to phone jack and pcb board.
2. Solder the wires connects to DC female jack and pcb board.
3. Insert the speaker wires to both channels.
Step 7: Cut Holes and Assemble Everything
Test connections and make sure everything fits in.
I did an awful job cutting the guitar, but it'll look better once it's assembled.
Step 8: Adding Bluetooth
Some amplifier has built-in Bluetooth, but not this one. The easiest way to add this feature is to get a Bluetooth audio dongle since LP-A68 has an USB port. BT dongle: https://www.alibaba.com/trade/search?fsb=y&IndexAr...
Step 9: Done!
You can use a guitar cable and a 6.4" to 3.5" audio converter to plugin your audio device, or you can use two short converter to make your phone "stick" on the guitar speaker (as shown in the pic). I also use a leather strap so I can hang it on the wall. I plan to add a chargeable battery inside to make it cordless.
    • Woodworking Contest
      Woodworking Contest
    • Planter Challenge
      Planter Challenge
    • Make it Move Contest
    12 Comments
    That's pretty narly. I'm definitely going to have to do this.
    More to the point, doesn't it resonate like crazy and emphasize certain notes? Especially the "note" you usually get when you tap the body!
    It does look good though :)
    No wierd resonance or "tap" you mentioned, it has a tiny electric hum when you stand very close to it though.
    Maybe you've got lucky, or just not noticed it :)
    But if you see anyone like KT Tunstall or Ed Sheeran playing an acoustic rhythmically, they actually make USE of the resonant sound of the guitar, tapping, slapping it. Acoustic guitar players will know the sound I mean, there is a distinct "note" to an acoustic guitar body, varies with size.
    It's far from an "ideal" speaker enclosure, which you normally don't *want* resonant peaks in, as it makes the sound ... peaky.
    Glad it's worked out for you! :)
    I'm not a hi-fi enthusiast, but I'm quite amazed by the sound it produce. It's not perfect, there's a slight electic hum when it's very quiet.
    Cool Speaker Enclosure! Can you still attach strings to the guitar?
    Haven't tried that, there's a bulge near the bridge which will cause trouble when tighten the strings, but I guess it'll be ok with a better shaped guitar.
    Nicely done and very creative! Great conversation piece!!
    Like it! Great project :)
