DIY HID Flashlight for your car/truck
Once or twice a year, my family and I go camping with some friends. Usually we show up at night and have to set up camp in the dark. This can get pretty frustrating using just regular flashlights and using car headlights is difficult to move around. So I came up with a way to make a HID flashlight that has become very useful for not only camping but is a great tool to keep in the car in case of emergencies (flat tires, etc).
Step 1Materials
Materials
Materials:
- Big flashlight that uses a 6V H3 Bulb
- 25 ft extension cord
- Cigarette lighter plug (comes with flashlight)
- H3 HID bulb
- HID Ballast
- 1 Large Zip Tie
- 1 Small Zip Tie
- Soldering iron
The flashlight that I used has an adjustable stand and a swivel handle which makes it very useful.
11 comments
Jan 30, 2011. 7:10 AM-max- says:
i hope you were VERY careful to not let that bulb touch your fingers or anything. some reason, this can shorten the bulbs life.
Jan 30, 2011. 11:10 AM-max- says:
do you know why, my theory is that while the bulb is hot, and the dirt (oil, proteins, dead skin cells etc etc etc) will vaporize on the bulb and weaken the super fragile glass.
May 7, 2011. 5:17 PMPreowner says:
Both HID and Halogen bulbs are not infact traditional glass (it can't handle the high temperatures). The bulb is actually quartz. The reason touching the bulb with your skin will cause them to fail is because the oils will cause the heat to build up and fisures will form in the quartz allowing the gas inside to seep out and air to seep in.
Sort of like the way oil from leftover food melts through a styrofoam container when in the microwave. if the oil was not there the container would be perfectly safe.
May 8, 2011. 1:30 PM-max- says:
I know the bulb is quartz. So that's why the bulb goes bad when touched...
Feb 2, 2011. 7:02 PM-max- says:
where did you get the flashlight from? is it one of those "dollar store" type of 6V lantern? what about the battery?
Feb 18, 2011. 3:38 PMMunchys says:
Why use a h3 bulb?
Mar 10, 2009. 5:31 PMReCreate says:
yes I've seen hid light kits somewhere for like 20 bucks
Mar 9, 2009. 10:53 AMbabloon says:
Great Instructables and easy to follow. I would suggest just one addition for security. It is best to use a 12v plug that have a fuse build inside, so if there is any shortcut for any reason, the fuse will blowup instead of making the wire to heat up and risk to get in fire depending of the value of the car fuse. And even if the car fuse blowup, it's often easier to change the fuse in the 12v plug than the one in the car, who often , are in a non comfortable place. The difference in the price worth it for the security and comfort it provide. P.S. Sorry for my limited English. I speak french.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:photemis
