3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY Hammock Stand
DIY Hammock Stand
We recently bought a portable hammock and we've enjoyed so much on our hiking and camping trips that I decided I wanted to hang it at home to enjoy on our backyard. I looked at the available hammock stands and they seemed quite expensive but very simple so I decided to give it a try. I based the design on some of the available commercial options. This is what I used:
2 - 8' 2X4 beams
2 - 6' 2X4 beams
2 - 4' 2X4 beams
8 - 5 and a half inch 3/8" bolts
4 - 6" 3/8" bolts
24 - 3/8" washers
12 - 3/8" tightening washers
Step 1Angled cuts.
Angled cuts.
The first step is to make the angled cuts of the beams that will hold the hammock, the 6' beams. I made a 30 degree cut so that the angle to the floor would be 60 degrees.
49 comments
1-40 of 49next »
Jan 28, 2012. 10:37 PMmatmore74 says:
I used only two bolts so that I had a stronger piece of wood and then breaced it in the middle and back. Thanks for the angle of 30. I used 7 ft 2x4's and put the uprights in about 10.5 inches in.. I then added four 2x4's for support cut the 30 and at 5' 4" and set back 1/2" and then bolted them. I them breaced it on the sides. Send me a email at matmore74@aol.com I will send you a picture of it and you will see what I mean. Put in the title area "hammock stand" Thanks for the idea on how to get it started..
May 16, 2010. 2:08 PMmaxpower49 says:
here it is after i added some 2X4's for better support
Jan 28, 2012. 10:27 PMmatmore74 says:
Thanks for the idea of the side supports. Its great for my stand.
Jan 28, 2012. 10:19 PMmatmore74 says:
I have read all of your issues and used them to make the weak areas strong. I breaced the midle and back then I breaced the sides. Now, I will say it made it heavy but strong. I weight at 264 and I was laying in it over night and it is very relaxing and had a great time knowing I used scrap wood and new bolts. I used the idea of the guy at the top of this articule and built it from you all. It is sweet.. So I want to say thanks to you all for you in put and thanks..
Jul 25, 2010. 4:37 PMddnova says:
Save your time and money, unless your looking for a temp. weekend frame then here's some things to add, you must use pressure treated wood only, regular spruce 2x4's will break from the load at the bolt holes, use 2x6 for the uprights as I only weigh 180 and thrid time using it one snapped at the bottom. Also most smaller hardware stores only sell 5 1/2" bolts in galvanized material, do not use these they will bend as they are too soft and as far as the cable support goes well once you add everything up including optional stain then your time you will be at, or beyond what a metal and portable frame sells for on E bay. Appreciate the plans but not for constant use.
Dec 14, 2010. 11:21 AMgeekzoid1 says:
Uhm pressure treating only prevents it from rotting it does not make it stronger. good advice otherwise. =D
Dec 12, 2011. 3:17 AMtim_n says:
Quite right, actually pressure treating makes it somewhat weaker as the water is pushed out for the treatment to be pushed in. This means that instead of getting a cracking sound when it's under too much load, you can have a sudden catastrophic failure.
Not so good when you're suspended over a wooden frame.
Jan 6, 2011. 9:09 AMkaway27 says:
My wife had always want to have a hammock in our back yard, so I made this hammock stand for her as a Christmas present. She loved it.
Jul 5, 2011. 8:14 AMkmedina58 says:
we really like your design. what are measurements and cuts to assemble
Jul 6, 2011. 9:25 AMkaway27 says:
I am glad you like it. I attached the detail drawing with dimension below.
Aug 23, 2009. 11:08 PMkiss2dave says:
Great design. I added the wire braces that suckmyinstrucables suggested (has to be wire, cord just stretches too much), using the hammock eyebolt on the upright rather than adding a dedicated attachment point - this transfers the swaying forces directly to the crossbraces without going through the upright, and saves by not adding another bolt. Before starting the cutting, lay out the base and uprights with your hammock to check it will fit correctly - I changed the upright angle from 60° to 45°, which not only gives it greater strength by making the hammock tension more longitudinal than transverse to the upright, but also gives it (I think), a more pleasantly nautical appearance. Also, if the raw lumber for your uprights are starting longer than the suggested 6' (I had bought 8' lengths) leave cutting them to length till last - that way you can make sure you have sufficient adjustment for your specific hammock - my uprights ended at 6'9", rather than the suggested 6'. Then I left on an extra 6" for a decorative top piece.
Aug 27, 2010. 5:58 AMSargel says:
Did you use pressure treated wood? And how much did the total setup cost?
Aug 30, 2010. 10:26 PMkiss2dave says:
Yes, pressure treated, particularly since it's an outdoor stand. I used decking lumber. Cost? About $60 or $70 altogether - those little bits of metal add up. Value to me? Priceless.
Aug 24, 2010. 4:58 PMEtotheMax says:
Your design looks awesome! What's the total length of the setup?
Aug 24, 2010. 7:19 PMkiss2dave says:
14' 11"., tip to tip. I eventually added 'feet' too, ie small blocks at the ends of the bases, to stop it from wobbling on my uneven patio.
Jul 6, 2010. 11:21 AMSargel says:
What's the hanging distance with this design?
Jul 6, 2010. 1:22 PMSargel says:
After looking over the plans and doing a little math, it looks to have a hanging distance of around 10.5' +/- a few inches, which seems perfect.
May 27, 2010. 5:43 AMKryptonite says:
Wow that's awesome! Nice job!
May 23, 2010. 2:45 AMgenericpenguin says:
Added the lines as advised by several of the comments. Works well. Did this for one of my nephew's school projects.
May 15, 2010. 10:09 AMmaxpower49 says:
THanks built one last night with my dad it works good i just have to get some cable or more 2X4's to brace it
Apr 28, 2010. 11:52 PMPompilidae says:
 These are some beautiful frames. I bought a hammock in the Yucatan where hammock hooks are sunk into the walls and the hammocks are taken down during the day to open up the room. Gordo (the man who I bought the hammock from) demonstrated how to sleep in them (diagonally). In High school I borrowed from their idea and attached cupboard door handles (the kind with four screw holes) to my walls (making sure to hit the beams).  The hammock is hooked up to the handles with carabiners and I got a much better nights sleep than I ever did in my flat bed. My back hurt less too.
However, now that I'm renting an apartment I don't think that would be appreciated. Your stand is fantastic. It'll be a great summer project.
Mar 21, 2010. 6:48 PMprestont says:
 Thanks a lot! I almost bought one but then decided to give making one a whirl with random old scrap wood and whatnot from the garage.
Instead of using cable for the side stabilizers I just used some 2x4s.
Apr 2, 2010. 8:06 AMpmdryd says:
THANK YOU! Man, I have looked all over for a plan like yours. I was hot to trot to buy a couple of wooden frames with quilted hammocks for my twin girls 'till I looked at retail prices. I'll make this and send pics if they are presentable.
Feb 8, 2010. 4:01 PMrck_mtn_climber says:
eno ftw
Aug 20, 2009. 3:33 AMAugust Spies says:
Thing is, I have yet to find a hammock that maintains tension after a few hours of sleep. So while i like mine with a bit of sag (and sleeping on a bit of an angle, as mentioned), I tend to get mine as tight as possible at the beginning of the night.
May 31, 2009. 12:32 PMsuckmyinstructables says:
So I just finished building this great stand. As has been mentioned several times, it is really not stable enough in the basic version. To increase stability significantly, I added wire rope diagonals between the ends of the feet and the middle of the top beam. This adds about 15 to 20 bucks to the overall cost but I'd say it's well worth it. I don't think I would trust the stand without them.
May 2, 2009. 7:04 PMwynberg says:
Made this one today and used a double brace on the crossbars. the only problem is I'm not really sure how to strap them together and attach a hook for the hammock. Any suggestions?
Jul 28, 2008. 10:19 PMdagmar31 says:
Waah. I just made one. It looks great, but I came upon a few issues... maybe my home depot is just crappy, but I realized that some of my wood was warped.. this made my base a little.. rocky, like, rock left to right a little. Second, I definitely noticed the sway of the upright 2x4's... I think what i might do is actually double up the 2x4's. Third, after some testing, one of my upright 2x4's cracked at the base. It was "pulled upward" as a result of the weight in the middle of the hammock. Do you guys think that running rope or cable from the upright 2x4's to the base will prevent this from happening? And last, I feel some.. weird lopsided tension on my hammock, like its forcing me to learn towards one side when laying down... can somebody help?
Apr 20, 2009. 11:21 AMabadfart says:
ya just check your wood befor you buy it try to get the least boed
Mar 25, 2009. 7:10 AMfidgety2 says:
what type of hammock do you have i have a eno single nest that is what i think you have but i can't be sure
Jan 20, 2009. 9:28 PMMOrmons says:
I HAVZ YOUR CARPET ON MY WALLL nice hammock too
Dec 2, 2008. 10:09 AMthemakeitguy says:
i was thinking about having some pieces go at an angle from the middle of the 6' beams to the ends of the 4' beams, that would make it more stable if you started swinging a little :]
Jun 26, 2008. 8:34 AMgtashie says:
Great design, but can anyone offer guidance on using this for a hammock with spreader bar? Will it be any different?
May 7, 2008. 6:16 PMleewhitford says:
I like the whole design of the stand. I beefed mine up for outdoor use and for an XL Hammock by replacing the 2x4 with pressure treated 2x6. This will require you to use longer bolts, but there is more area for the bolts so you can add a few more for strength. So far it has held over 350 lbs with minimal sideways bend. I see it constantly evolving..
Jan 22, 2008. 7:20 PMbikeparts24 says:
I have been thinking about making one of these-I'll probably do it like this stand. How long is your hammock when it is flat on the ground? Thanks, and great instructable -Sam
Aug 18, 2007. 8:08 PMPopcornfilms says:
perhaps consider running rope, or cable from the place where you screwed in the Ihooks, to the floor brace. to allow it to hold more weight. great job!
Jan 13, 2008. 2:32 PMhassi says:
Exactly what I was thinking...Sort of like the red lines in the attached photo.
Jan 15, 2008. 4:44 PMPopcornfilms says:
ya exactly!
1-40 of 49next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:vicbp
