3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY Handyman's Pocket Sized Tool Box, Feat. Home Made Screwdriver
DIY Handyman\
By the end of this instructable, you will have a tool box with multiple screw bits, sockets, and hex keys. What's better than being able to repair and fix anything at your disposal on the go? Nothing of course!
This tool box is highly personalizable. You can add many more things as long as it fits in. For example, if you can put the more common socket sizes in as well as your favourite hex keys. Think of the possibilities!
Step 1Gathering.
Gathering.
To make a mini tool box, you will need:
*a small box (in this case, an Altoids tin)
*rotary tool with cutting disc and sanding drum accessory
*needle nose pliers (these work best)
*hot glue gun (or any substitution of adhesive to make the bonds more permanent)
*SAFETY GOGGLES! (don't want to be blinded and have a perfectly useful pocket tool box now, do you? :D)
*cheapo multitool retrieved from companies and such (I'm sure you can find something like it at a dollar store of some sort; look around, shouldn't be too hard)
Things to put in the tool box:
*mini hammer (found at jeweler's store)
*set of hex keys/allen wrenches
*screwdriver bits
*sockets
Now, on to building our feature presentation: the mini pocket screwdriver (compatible with screwdriver bits)!
Beware of imitators, especially ShamWOW ones.
11 comments
Nov 21, 2010. 11:50 AMBrian857 says:
It looks like you have a lot of extra space...
You could add some screws, nails, nuts, bolts, etc in it
Feb 14, 2010. 1:29 AMtongpu says:
 first off. WHERE DID YOU GET THAT HAMMER!!! I have to know.
second. this is awesome.
Oct 28, 2009. 3:57 AMsharlston says:
hey could you fit a tiny ratchet in there?
if you can put a tiny magnet in the bottom of a 6.5mm socket then attach it to your ratchet and pop a little screwqdriver but in the bottom and you have your own mini screwdriver
Jul 9, 2009. 10:48 AMcannedheat says:
it may be wise if you can find another, to attach one of these couplers on the long end as well. being that I ride a lot, i find that often the tubes of a bike frame can prevent the use of those allen keys short ways. it may be helpful for reaching front derailleur high/low screws and other harder to reach spots.
Jun 30, 2009. 5:50 PMIslmi says:
I took an hex adapter off of a bit set I had sitting around, and pulled the grey end out of it. Then I used a bench grinder to file it down, and superglued a small magnet in the middle of the inside of it. Thus, I had the metal equivalent of your plastic coupling, and it was removable. Makes fitting everything inside of the tin a lot easier. Kudos, great instructable.
Jul 7, 2009. 5:20 PMtech_sponge61 says:
do you know where i could buy the hammer online? when i google jeweler's hammer it gives my ball pin hammers and such. nothing as small as the one you use.
Jun 22, 2009. 2:45 AMironsmiter says:
that hammer is SO CUTE! I can almost imagine the lilliputian nails you'll be driving with that! The allen-key turned screwdriver/socket wrench... that's an instructable all in itself, but blends well with the kit. Kudos. I would suggest though, a drop of superglue will do better for holding the magnet... Now if only they'd make an altoids tin to fit my Leatherman multi-tool. especially since it has a bit adapter built in(have to take out the adjusting screw, but it's there)
Jun 22, 2009. 5:18 AMsrohwer says:
Why not make a clamp out of a second Altoids tin to hold your Leatherman? It seems like it would be easy enough to pop rivet one to the top or bottom.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
14
Author:=D
It takes half your life before you discover life is a do-it-yourself project. - Napoleon Hill
