Introduction: DIY Hanging Fairy Light Jar
A simple battery powered lighting solution for every day or a special occasion
Step 1: Step One:
Start by painting the rim of the bottle using any colour that matches your decor, I’ve chosen to use gold. Then take your string and fix it tightly around the neck of the bottle.
Step 2: Step 2:
Cut 3 pieces of string to your desired length. This is a good time to measure where and how low you would like to hang your light. Cut each length long enough that it can be doubled over while also adding enough to allow you to tie off your ends. I used a Bobby Pin to slide the end of the string under the tightly tied band.
Step 3: Step 3
Side all three lengths under the band, double them over and evenly space them so that they become the strings that will hold the bottle up.
Step 4: Step 4:
Slide the band flush against the painted rim of the bottle and put the lengths inside so they don’t get in the way. Use double sided tape to hold down the loose ends of the band and the start of the string that you use to wrap around the neck of the bottle. For a clean finish that will conceal the battery pack, make sure the string is wrapped around the neck of the bottle evenly layer by layer.
Step 5: Step 5:
Next trace and cut a circle the size of the rim of the bottle from a piece of cardboard.
Step 6: Step 6:
Then use double sided tape or glue to attach the battery pack to the reverse side of the cardboard. Feed the wire lights into the bottle and place the cardboard on top as the bottles lid.
Step 7: Step 7
Tie together the lengths and your new light it ready to hang!
26 Comments
This is such a great idea!
I like the gold accent along with the wrapped string.. it makes for a very cool look. Nicely done! :)
Thanks so much xx
Thanks so much! If you haven't watch the video version yet click this link to check it out! https://www.youtube.com/channel/UCFo46J5HZ8XTce_wGfuKORQ
Nice! You should add a step and embed your video here. That's a good way to double up your effort.
Great first instructable too. This is a perfect write-up of a clever, reproducible project!
Good effort! So is this some kind of special string? I have never seen this before. It might be nice to mention it in the beginning for noobs like me. :)
To shop the supplies for this video go to my website, shethemaker.com
Hey, it's not any special type of sting, anything that's not to stiff and will wrap easily is a good idea! :) for a bit more detail watch my video
https://youtu.be/_x5RAMMxgkg
This is so pretty - gorgeous photo and great job!
Thanks so much xx
Thanks Holly, if you want to see more check out and subscribe to my YouTube channel https://www.youtube.com/channel/UCFo46J5HZ8XTce_wGfuKORQ
