DIY Headstock Chuck Tailstock Spindle Homemade Wood Metal Mini Lathe Projects Milling Slide CNC
Published
Introduction: DIY Headstock Chuck Tailstock Spindle Homemade Wood Metal Mini Lathe Projects Milling Slide CNC
Materials:
1 pcs chuck drills spindle 13 mm
2 pcs 12 mm x 28 mm x 8 mm black double rubber sealing cover deep groove ball bearing
1 pcs motor 50 watt take from old hand drill
1 pcs Special round steel pipes 12 mm x 100 mm
1 pcs Aluminium 70 mm x 40 mm x 35 mm make hole 28 mm
1 pcs strength aluminum alloy 42 mm Motor bracket DC Motor Fitting
More Homemade Scara Robot Arm DIY Robotic Frame Projects Laser 3D Printer Draw here:
    • Make it Move Contest
    • Oil Contest
      Oil Contest
    • Casting Contest
      Casting Contest
