DIY St. John's Wort Healing Salve
2,308
67
5
Published
Introduction: DIY St. John's Wort Healing Salve
About: I love DIY!
This salve can be used on your entire skin, as well as on the lips. It is great for treating wounds, burns, bruises, bug bites, and so on.
It contains the following ingredients:
  • 5 tablespoons of St.John's Wort oil
  • 2 teaspoons of beeswax
  • 3 drops of vitamin E oil
  • 5 drops of any essential oil
Read more about this recipe on my website: DIY Herbal Salve with Healing Properties
Step 1: Mix St. John's Wort Oil and the Beeswax
Mix 5 tablespoons of St. John's Wort oil and 2 teaspoons of beeswax in the pot.
Step 2: Melt Macerated Oil and the Beeswax in a Double Boiler
Put the pot with the mixture of oil and beeswax on top of a pan of simmering water so that those two would melt.
Step 3: Remove From the Double Boiler and Add Vitamin E (optionally)
Optionally, add 3 drops of Vitamin E oil. Vitamin E is an antioxidant so it will prolong the shelf life of the salve but it is not necessary to use if you will use the salve in a short time.
Step 4: Add Essential Oil of Your Choice
Add 5 drops of any essential oil. I used peppermint.
Step 5: Pour the Salve in the Container
This step should be done immediately after you mix everything up because the beeswax tends to solidify really fast so if you wait you will have a hard time pouring it in the container.
That's it! Your herbal healing salve is finished.
    • Make it Move Contest
    • Stick It! Contest
      Stick It! Contest
    • Oil Contest
      Oil Contest
    5 Comments
    was actually hoping for more fresh ingredients (especially what you call st johns wort or hypericum perforatum)
    the essential oils you add can also add to the positive properties of the salve (lavender for example to great burns and scarring) that said, there are oils and "oils" meaning there are the oils that are produced from the plant and imitation oils that just smell like the real deal.
    nonetheless this is going on my list to make ;)
    Yes, various essential oils can go into this recipe, depending on what you need the slave for :)
