3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY Heatsink for Small Transistors
Here's a little mini-instructable:
Want to squeeze a bit more current through those inexpensive TO-92 package transistors? Then add a small metal heatsink.
I made this for a PWM DC motor driver, as some 2N2222 bi-polar transistors were handy. It worked OK, but the 2N2222 was getting very hot (too hot to touch.)
This will work with any TO-92 device--but the device must have a flat part to contact the sink (as TO-92 cases do.)
It's not entirely crazy; commercial heatsinks are available for this package. And the 2N2222 specs include two power dissipation ratings, Tamb <= 25 C (500-800mW) and Tcase <= 25 C (1.2-1.8 mW) (being ambient air temperature and case temperature.) Keep the case at 25 C or below, and the current rating more than doubles.
Step 1You'll need...
You\
Materials:
-- Heatsink material: copper, aluminum or other sheet metal
-- Heat shrink tubing
-- Thermal paste compound (for CPU heatsinks)
Tools:
-- A nibbler (or tin snips)
-- Files and sandpaper
46 comments
1-40 of 46next »
May 26, 2012. 10:17 AMmgingerich says:
Great little instructable. This should keep my CNC controller from melting itself :)
Nov 4, 2011. 10:19 AMElectorials says:
epic!
I've never seen anything like this before,
5 stars ^^
Jan 4, 2011. 4:43 AMbeehard44 says:
lol nice idea
finally i can use my lm317l to give me 1A
Dec 22, 2009. 3:59 PMrocketman221 says:
Good idea. I have used aluminum tape before, but it gets bent out of shape easily.
Feb 28, 2008. 4:45 AMcomodore says:
How can I make a heatsink for a big transistor like this one in the pictures?
Dec 22, 2009. 3:43 PMWesley666 says:
You can buy heat sinks for these.  All they are is a square with sides bent up like this:
l___l
*If the picture above doesn't work this should:
l......l
All the way around.  Then cut down the sides every .6cm or so and drill 2 holes for the pins and 2 more for screws and the collector connection and that's it.
Nvm both pictures work...
Dec 14, 2009. 10:19 AMJodex says:
Stupid question comes here, but I have to ask because I'm not sure. Is the casing of that transistor its base or something? Thanks for the answer.
May 6, 2009. 4:20 AMomnibot says:
Drill a hole in a big metal plate and screw it in.
May 7, 2009. 1:14 AMcomodore says:
Nah, that is to easy... ;D
May 9, 2009. 6:06 AMomnibot says:
Not if it's six inches of steel and you use a handpowered drill it isn't.
May 14, 2009. 10:43 AMcomodore says:
Well... :D
Apr 29, 2008. 1:31 PMXellers says:
Just find an old computer, rip out the CPU heatsink and fan, and get some thermal paste. Apply the thermal paste to the transistor and stick the heatsink and fan assembly to that. From there, if you really want to, you could wire the fan up to some sort of power supply and that would solve your problem.
Jun 22, 2011. 9:56 PM_Scratch_ says:
How big of a transistor is that?? New cpu heatsinks are designed to dissipate a LOT of heat.
Mar 21, 2008. 8:41 AMsteven123654 says:
I will soon add a instructable on how to do so (with a CPU fan and it heat sink)
Mar 21, 2008. 1:15 PMcomodore says:
OK. Thank you!
Mar 27, 2010. 9:25 AMbeehard44 says:
well, i salvaged a lotta devices wid heatsinks, and some use thermal mat or some sort. instead of thermal paste, that is used. It is like rubber, but not rubber
Feb 28, 2008. 8:00 AMcomodore says:
Thank you!
Apr 25, 2009. 5:30 PMCapt. Howdy says:
Nice. I'm gonna use this on an upcoming project.
Nov 9, 2008. 9:58 PMKoil_1 says:
On this same kind of transistor I usually just cut the heat sink with a tab that wraps around the IC. I can definitely see how this would work pretty well. I like the heat transfer from a crimped on heat sing a little better. It can easily get out of hand though, if you crimp it to hard. If you do, it breaks the chip which is considerably bad if you still want to use it. Kudos on the innovation. It's a much safer way to apply a heatsink to a small chip without a mounting hole.
Mar 4, 2008. 12:54 AMPrometheus says:
I like the project, but I suggest that the heatsink actually wraps around the casing to improve heat-transfer to it. Aluminum is best for this, and I can suggest using a soda can for scrap aluminum that is sufficient for this task. Also, keep in mind that thicker heatsinks are for handling surg3es, thinner ones are for more continuous duty. There is no such thing as a heatsink too big. Employ as much surface area as you can, and you can see results far beyond expectations until you actually start burning-out junctions. Crazy as it may sound, heatsinking the leads themselves can actually help too. Solder copper foil to the pins over the surface-mpount, and even more power can be pushed through, just make sure they don't touch.
Feb 22, 2008. 5:00 AMflagbuff says:
Very Clever! thank you!
Feb 13, 2008. 7:07 PMacaz93 says:
Very useful , specially if you have to switch some motors , Cool pictures Btw
Feb 13, 2008. 9:03 PMacaz93 says:
im using it for controlling a Relay actually , it heats up quickly since it's hardcore Fast switching!
BTW:have you seen(*)The Solenoid Concert ? (8)
Feb 15, 2008. 11:17 PM1up says:
Dude! That is awesome! I should do that using a parallel port...
Feb 13, 2008. 11:07 PMMaxx1 says:
I feel bad for that poor transistor. I understand when your in a pinch for a part but I would rather get a part that is more rated for the task.. Good instructable tho....
Feb 15, 2008. 10:49 PMrc jedi says:
Testing to failure? that's what i do to my cars!
Feb 14, 2008. 1:46 PMcharper says:
I also couldn't help but thinking "poor breadboard". Excessive current can be very destructive to them too.
Feb 13, 2008. 8:09 PMGorillazMiko says:
Awesome Instructable! Pictures are great too.
Feb 14, 2008. 8:24 AMc0redump says:
Just thinking about the last photo, where it shows the heatsink held on with heat-shrink sleeving. Now, if the thing gets REALLY hot, the sleeving will melt and the heatsink will fall off, making a bad situation much worse. Could you hold the heatsink on the transistor with metal, somehow, so it would never fall off?
1-40 of 46next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
120
Author:gmoon
