3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY High-Speed Book Scanner from Trash and Cheap Cameras
Step 37Firmware/Camera Setup
You'll need at least one working camera to move this project along. Firmware installation is step 1. Because it is so complicated, I made a video for you to follow along with rather than typing out ten thousand confused words.
The full version is here if that copy is illegible:
http://fakeproject.blip.tv/file/2009463/
Please note the mistake I made in this video. Apologies again for the low-ish production quality.
« Previous Step   View All StepsNext Step »
6 comments
May 9, 2009. 3:37 PMmoddi says:
If each of my cameras has different firmware version, do I do a different setup for each?
Jan 4, 2010. 4:46 PMhyperdyne says:
moo.
Apr 27, 2009. 2:19 PMautophile says:
Step 37: Two helpful hints: 1. Somewhat obviously, as you watch the video: You will need two Canon cameras, and they must be on the list of supported cameras at StereoData Maker. 2. Less obvious: Use an SD or SDHC card of 4 GB or less. Higher capacity cards require partitioning, and that is only supported on some Canons. A 4 GB card will still let you take around 1,000 images per camera.
Apr 27, 2009. 6:31 AMautophile says:
Step 37: To get the firmware version, set the camera to PLAY, then hit SET (or FUNC SET) and DISP at the same time.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
141
Author:daniel_reetz
Hacker, Artist, Researcher, and founder of the diybookscanner.org community.
