3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY High-Speed Book Scanner from Trash and Cheap Cameras
Step 43Display Systems: Overview
The two scanners I've built so far feature two different display systems. You should strongly consider using some display system on your scanner, because plugging the cameras in to a display not only DOUBLES your battery life, it also saves you from craning your neck around at the camera to check the see if it has properly focused on each shot. I discuss this a little bit in the "technical overview" video.
Both display systems are recycled. The first display I built is from a modified portable DVD player. My dad bought it for my late grandpa Stanley Reetz to watch movies on, but it didn't work for very long. The DVD player portion of it stopped working, though the display would still light up. I had it in my closet for several years, hoping to re-use the LCD. As it turns out, it was possible to modify it for video input, but it had some power management smarts and would turn itself off after ten minutes. So ironically, I had to disable power management on this device to reuse it in a green way. ;)
« Previous Step   View All StepsNext Step »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
141
Author:daniel_reetz
Hacker, Artist, Researcher, and founder of the diybookscanner.org community.
