3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY High-Speed Book Scanner from Trash and Cheap Cameras
Step 59Handle/Electronics: Hub 2.
Open it up. We are going to cut off the USB connector, but we need to determine which pin is positive and which is ground. The easiest way to do this is to plug it into your computer and use a multimeter to see which pin has +5V on it. In this case, +5V turned out to be the leftmost wire -- the red wire -- and ground was the brown, rightmost wire. This is probably pretty consistent between hubs, but you should test yours anyway.
« Previous Step   View All StepsNext Step »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
141
Author:daniel_reetz
Hacker, Artist, Researcher, and founder of the diybookscanner.org community.
